Cabbage
    Mon Apr 06, 2020 4:25 am
Hi all, I'm new here and to welding, so go easy please :)
I'm trying to lay down some practice welds on a 1.5mm bit of stainless. My welds consistently look like they've oxidised (I think...). I'd like some help on what's going wrong and why I can't lay down a shiny weld.
Welder info:
  • Torch WP9 - 5 cup and 5 cup with gas lens. 1.6mm sharpened tungsten (both red and white tip)
  • Gas - Pure Argon - and I've tried between 5LPM and 10LPM
  • DC - 40-45amps, No pulse, pre flow 0.5sec, post flow 8 sec
  • 1mm and 1.6mm filler rod (316L and A15),
  • welding stainless box section that has been scotchbrited and acetoned so I believe it's clean?
My thoughts were it could be:
  • too slow travel speed and therefore too much heat in the weld
  • not enough gas flow
  • too much gas flow
  • air leaking into the system
  • Torch not upright enough
  • contaminated tungsten
  • Too much torch height
  • Too much stickout
I've done my best to eliminate all of the above or try variations of things to see what helps. I am new to this so it is probably something very fundamental I'm getting wrong. Pics attached, please note in a couple of welds I've dipped and carried on, but all my welds are consistently crappy looking, regardless of whether I've just cleaned the tungsten. Also on some of them I really raced through to test whether I was being too slow, and I don't have the skills to lay down anything neat yet, so ignore the fact it looks like a 4 year old laid those beads haha. And apologies but I can't remember which photos had which settings, I think the 20200406_085547.jpg pic had the gas flow dropped to 5LPM. I'd appreciate any feedback anyone has. Thanks.
Incorrect gas flow. Either to little, wind or fan blowing it away, or a leak on your torch drawing in air.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
Cabbage wrote:Hi all, I'm new here and to welding, so go easy please :)
Welder info:
cup is way to small.
i would use an 8. fairly typical size. stainless loves argon.
amps sounds close enough. but you may want to look at more amps and increase travel speed. travel speed is king with stainless.
Cabbage
Thanks guys, biggest cup I have to hand is a 7, so I'll try that first and see if it improves. Failing that I'll work through the other suggestions!
Cabbage wrote:Thanks guys, biggest cup I have to hand is a 7, so I'll try that first and see if it improves. Failing that I'll work through the other suggestions!
#7 is way too small. Think more like #10-16 gas lens. Yup. Thin sheet will get overheated quick, and you need to keep the beads short enough that the beginning of the bead does not escape the argon shield. If it does, that's why its oxidizing. Another thing that will help tremendously is active heat-sinking via chill-bars of some kind, whether they be copper or aluminum.
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
All of the above.
Anything under 2mm in staino I pulse. It takes your weld finish to another level. If you have it use it. That's what it's for.
Cabbage
Thanks for the advice all. I'll try it out.
Spartan
    Fri Mar 06, 2020 8:59 pm
The Furick #12 cup (I use the ceramic) is an absolute champion for welding stainless. I run it with about 25 CFH and about 9/16 - 5/8" stick out unless I happen to need a longer stick out. Love it. Jody sells them on weldmonger, and you can also buy cups directly from Furick.
    Mon Feb 26, 2018 1:52 am
    Idaho
You should be OK with a #7 or #8 gas lens, but bigger would be better. Once you go above a #8 I find that you NEED the extra diffuser.
For example going from a #8 to #10 CK pink cup, I find that the #10 is not as good a cup and I get better results with a #8. If I use a #10 or #12 furick that is a game changer with that extra diffuser.
You should be between 7 and 10 LPM with a #7/#8
Run a few beads without filler at different travel speeds you should be able to get a shiny bead, otherwise you likely have something wrong.
Simclardy
    Mon Jul 24, 2017 9:41 pm
    Cape cod mass
Some guys like to use a standard #5
But i use a furick #12 and a trailer on thin stuff.
You have a gas coverage issue.
I would use at least 1.5 pre flow and and try 12s post for now.
Try to do one dab without traveling. This eliminates some of the"operator error".
It should look nice and shiny. Then you will start to weld and notice your last little bit looks good and the rest not so much. At this point you learn to move quicker and increase your gas coverage, hence the#12
Cheers
TraditionalToolworks
    Mon Dec 18, 2017 7:49 am
    San Jose / Kelseyville
I don't know, it seems these new welding cups are getting out of control... :lol:
Collector of old Iron!
Alan
Simclardy
    Cape cod mass
Lol
:lol: :lol: :lol:
