UniqueTouch
- UniqueTouch
is it possible to use ck worldwide ck210v fx air on lincoln square wave tig 200. I just bought it which i got a great deal on it is 2 piece though. Anyway for me to use it? thank you for your help guys. Always very appreciated.
UniqueTouch
- UniqueTouch
Thanks for replying i appreciate it. Ive been looking just not sure. I saw one video whee the guy who owns a store showed an adapter for it he said screws into the port for the torch but i dont need how it could thread in. Hoping someone has done it and will know but again i do appreciate it.
https://weldfabulous.com/welding-suppli ... 1&brand=56
Lincoln Electric
Lincoln Electric K960-1 Twist Mate Torch Adapter
$74.99
I think this is the adapter you need
Lincoln Electric
$74.99
UniqueTouch
- UniqueTouch
Hey Sim thank you for replying i appreciate it very much. All i wanna do is weld 24/7 and use my new torch lol. I actually have that exact piece pretty much. My only problem is that I need a piece that I can take the wire connector off the tig torch electric connection wire and I need one that i can mate it with to connect to the dinse that i have.
The only other piece is the hose.
Am i missing something? Can you post a picture?
I know the feeling of wanting to weld and having to wait.
Cheers
Cheers
UniqueTouch
- UniqueTouch
Has that hose that connects but how can I connect the power supply
- 5FFE6683-DA6E-4719-90E7-E36FD40340DC.jpeg (35.9 KiB) Viewed 1585 times
UniqueTouch
- UniqueTouch
Disregard the Dinse in the bottom right of the picture. That is one I bought a while back just put it in the box so I don’t lose it
UniqueTouch
- UniqueTouch
looks like im going to just gave to buy another house and dinse connector so much for getting this for 100 lol gonna cost me more now lol
The black hose is your power supply.
This is an air cooled torch? The power and argon hose are dual purpose. On water cooled you have 3 hoses. Cold h20, hot h20, and gas/power.
If you look at your machine, does the gas come from a separate port? Or from the power dinse connector? Ck makes adapters for both options.
UniqueTouch
- UniqueTouch
UniqueTouch
- UniqueTouch
21HPCA (2310-1879) that is the part number i believe i need but if my machine has the dinse connector ports on them how would I attach that and than plug it in? I dont know how to explain it unfortunately without being in person.
I know, i wish i was there.UniqueTouch wrote:21HPCA (2310-1879) that is the part number i believe i need but if my machine has the dinse connector ports on them how would I attach that and than plug it in? I dont know how to explain it unfortunately without being in person.
Look into your negative dinse port. Do you see a hole in the middle? That is where the gas comes out. Look at your positive dinse port and it should look different
UniqueTouch
- UniqueTouch
Yes there is a hole that goes through currently I have a ck130 that works on it but it is one piece ck torch. The ck210v I bought is a two piece. Which I didn’t realize until it came in the mail
