Another Syncrowave Unstable AC Arc Question
Posted: Tue Jul 30, 2019 10:34 pm
I’ll try to post what I know as succinctly as possible but forgive me if it’s a little long-winded.
Working on a Syncrowave 250, water cooled, ser. LA158321. I don’t know the vintage.
Job is 6061 T6 .190 thick, 2f t-joints. I am a machinist with limited welding experience, these are my first t-joints on aluminum but have successfully worked with steel/stainless a fair bit.
- Torch is a brand new CK Flex-Loc, new gas lens, 3/32" blue and gold lanth. tungstens both tried, sharp and blunt points both tried.
- Settings are ~210 amps, High Freq continuous (control on position 10), AC balance 10 (manual indicates this is 68% electrode negative), postflow - just enough to prevent tungsten discoloration.
- I have cleaned and set the spark gap to .008, cleaned and tightened the posts, and even checked the ground cable for resistance.
- The material was prepped with IPA, dedicated stainless brush, and/or Scotch Brite wheel. The tungsten, filler rod, and table surface were also IPA’d.
My problem is that I cannot get a nice teardrop shaped arc cone that will penetrate into the corner of the t-joint. My cone is truncated, like the dunce cap I had to wear in school, with the large end of the cone presented to the work. Nothing I do will tighten this up, the arc just dances all around, randomly swapping from the one part to the other. I’ve tried every combination that I’ve watched or read online, never getting an acceptable arc. I’ve tested the AC Balance control and it does at least function at the extremes so I don’t think it’s that. I’ve tested with both slowly bringing up the amps, and mashing the pedal at a higher setting (as recommended by some). When a higher amperage is used and the pedal mashed, it will blow a 1/2" hole through the 3'16" material in a second or two. I don’t imagine that’s right but I think it at least rules out an insufficient line source. These t-joints are 3/16" from the edge and the arc will randomly jump over and melt the corner, it doesn’t matter where I’ve got the pedal, or at what angle I approach, it just won't burn into the corner. Even when running beads on flat plate, the cone’s truncation causes the bead to be too wide, it’s only possible to tighten it up by backing way off of the pedal, but then of course, I get no penetration. I found a couple of practice plates from a few years ago and they had nice tight beads with adequate penetration so I’m believing that this has worsened over time or is a new problem.
If this is a board issue rather than something I’m doing wrong, I have the ability to test and replace components if someone knowledgeable can point me in the right direction. If it’s something I’m doing, I’m more than willing to test any suggestions. Thank you.
