TIG Welding 0.065 Wall SQ Tubing issues
Posted: Mon Aug 01, 2011 4:55 pm
Maybe some one can tell me what I'm doing wrong. Every time I try to TIG weld on 0.065 wall SQ Steel tubing, the weld seems to bubble up. I'm welding at around 90A, 15CFH Argon with 1/16 2% Thoriated rod.
I've cleaned the tubing to remove all the mill scale, but still the weld bubbles up. WTF? Do I need to purge the inside of the tube with Argon?
Thank you for your time.
