This Didn't Work
Posted: Mon May 27, 2019 8:44 pm
by Downwindtracker2
I was trying to weld an 1" aluminum angle to a 1" square tube. Both 1/8". I coped out the tube so the angle would lay flat. I was able to weld the edges but the interior right angle looked like a "product of Fido's butt". What should I do next time.
Re: This Didn't Work
Posted: Mon May 27, 2019 9:46 pm
by tweake
got a pic?
Posted: Tue May 28, 2019 12:06 pm
by Downwindtracker2
No, my computer skills involve finding the keys when I type.
To get into the corners, I switched from a gas lens cup into the smaller orifice style that came with the welder. Basically I couldn't TIG weld a corner joint . It was my only piece of aluminum square tube, so I didn't get a do over. It was for an electric trolling motor mount that would fit in the launching wheel bracket on my tinny.
Posted: Tue May 28, 2019 12:07 pm
by MinnesotaDave
Without knowing specifics, I can say that inside corner (fillet welds) require more amps to get them to lay in right.
Get on the power and go for it - be bold
Posted: Wed May 29, 2019 7:02 am
by Warrenh
Extend your tungsten stick out and add gas. Maybe 25 or 30 cfh. You should have no problem then.
Sent from my moto g(6) (XT1925DL) using Tapatalk
Posted: Wed May 29, 2019 2:01 pm
by Downwindtracker2
Thanks. I was talking last night with my son at my granddaughter's pre-school graduation, an excuse for a concert. He suggested sanding the aluminum. I have been using a SS wire cup on a mini grinder. What type of sanding discs would you suggest for the mini grinder?
