Bishop0517
    Wed Feb 13, 2019 5:28 pm
I've been DC tacking aluminum now for close to 15 year now with A75. I thought if you could weld aluminum you knew this trick. But apparently my night guys have never seen it and are questioning my methods. Every site I've been on says it's the preferred way to tack. Is there anything in AWS D1.1 that pertains to this process?
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hi there, 1.1 is for steel, 1.2 is aluminium. That's as far as I can help though.
ljdm1956
    Wed Mar 19, 2014 6:29 pm
    East Durham, NY
Bishop0517 wrote:I've been DC tacking aluminum now for close to 15 year now with A75. I thought if you could weld aluminum you knew this trick. But apparently my night guys have never seen it and are questioning my methods. Every site I've been on says it's the preferred way to tack. Is there anything in AWS D1.1 that pertains to this process?
What gas are you using to DC Tig Al? Even if only tack welds, I thought you needed Helium in the mix for any success.
Lincoln Weld-Pak 180
Lincoln spool gun
Everlast PowerUltra 205p
AHP AlphaTig 200X
Assorted stuff
Yea, like 100% for welding
