hi all,
it's some weeks i'm stuck in a problem i'm not able to solve. i'm an hobbist and i'm trying to improve.
i'm trying to realize a project in mild steel, 3mm thick. the design use a piece of square tube 40mm that match a 40mm plate. you can see it in the picture.
i dont have any problem with the corner fillet in the opposite side. 110amp, 2.4 tungsten, 2mm filler. furick 12. works like a charm.
when i try to weld the corner in the picture... same seetings, same gas, same tungsten extension.. disaster. a lot of porosity.
i also have problem on find the best approach for this tight space, if start welding from the corner to the center or vice versa. i tried several approaches.. and i cannot say i found one better than the other.
i'm pretty sure if i remove this little lip with grinder i will get an acceptable result, but i would like to improve.... learn what to do in this kind of situations.
any help is welcome!
thanks,
David
hi Richard, thanks for answer.
my flow rate 15.5 l/mn, around 26 cfh. i tried to increase it to 30 cfh. result was slightly better.
today i dd another test. i used 2 flat bars this time, 3mm thick, 3mm gap from the border (as in the part i have to weld). i lowered amp to 95, maybe a bit too hot... but worked well without porosity.
probably you are right, uncomfortable position + tight area make me keep a longer arc.
David
David
