falconav8r
- falconav8r
I have been trying different tungsten for aluminum welding. 2% lantanated, 2% ceriated, 2% thoriated. 2% thoriated has always been the go to, however after welding for a few minutes the tungsten does not keep the shiny ball end, instead it seems to split and appears contaminated. The aluminum is very clean, acetone wiped on project as well as the rod itself. 1/8" aluminum, 20 CFH argon, 145 amps max on foot pedal, with or without pulse. Weld quality and appearance is excellent but tungsten always needs regrinding
Hi there, this can happen due to contamination of the shielding gas itself, or a pin hole leak in the line, drawing in air. Try a different welder with the same bottle or a different bottle that's known to be good. Also too, the tungsten stick out can be critical if not using a gas lens, don't have more than 6mm of stick out
falconav8r
- falconav8r
Thanks for the answers to my question. I forgot to mention I am using a #7 gas lens, A/C balance 35%. Changed the argon and the difference was immediate.
falconav8r
- falconav8r
Still having the same issue. Aluminum is very clean, AHP Alphatig 200DX, A/C balance 35 - 40, Frequency 75 - 100, 20 CFH argon, 2% Lanthanated or 2% Thoriated, 2% Ceriated 3/32. Same results. See attached pic.
- tungsten.jpg (18.87 KiB) Viewed 1478 times
Check your post flow, should run long enough to keep the tungsten silver.
Also check actual flowrate at the cup with a meter like this:
Often a regulator gauge can't be trusted. These are cheap from fleabay etc.
- flow meter.jpg (14.33 KiB) Viewed 1473 times
post flow will help.
i often make that mistake due to being to cheap on the gas.
also tungsten grind. looks like you have a pointy tip. i would flatten that off more. eg make it look more like a crayon.
145 amps is on the upper limit for AC in my opinion using 3/32" - I would usually jump up to 1/8" - some batches / brands hold up better.
