Best place to buy (get) material for practise
Posted: Tue Nov 20, 2018 8:16 pm
by n3nman
New to TIG welding and I have a good bit of scrap aircraft grade material (4130 and 7075-T6) but would like to get a good bit of 5052 or 3003 plus some mild steel for practise. Local in Atlanta. Anyone reasonable in the area. Already called a couple of "Steel" places without much luck. Someone needs to "sell" a coupon kit for beginners. Thanks
Re: Best place to buy (get) material for practise
Posted: Tue Nov 20, 2018 9:58 pm
You can often get decent deals on some drop from larger Steel Suppliers. Or, you might find a local Metal Supermarket branch near you. They too have small stuff. They’re franchises, so if you introduce yourself to the owner, make a deal to pick up their scrap, weld on it, then return it to them for salvage, it’s a win-win. You get practice material, they get it back weighing more!
Posted: Wed Nov 21, 2018 6:49 am
by tungstendipper
Go to your local community college that teaches welding and asked them where they get their steel. Many will give you some coupons to weld with. While you're there, check-out their night courses.
Posted: Wed Nov 21, 2018 7:12 pm
by ljdm1956
Pricey, but Lincoln welding, www.JFLF.org has coupons for sale, at that address, "project kits" at the top of the page.
Posted: Fri Nov 23, 2018 9:32 am
by crashbandit
Also you can search eBay for that too. Lots of drops and stuff on there. I’ve seen pretty much everything you have been asking about in a simple search on there.
Posted: Sat Nov 24, 2018 10:44 pm
by koenbro
My local steel supplier has cut offs from larger orders, for $0.65/lb for steel and $2.25/lb aluminum I check them out the about once a month and basically pick up their leftovers.
Posted: Sun Nov 25, 2018 10:27 am
koenbro wrote:My local steel supplier has cut offs from larger orders, for $0.65/lb for steel and $2.25/lb aluminum I check them out the about once a month and basically pick up their leftovers.
Those are good prices
Posted: Wed Dec 12, 2018 1:48 pm
by ROBERTINCREST
I think I'm going to try and find a shop or mfg that uses the steel or aluminum that I want to practice on.
They all have scrap bins that they recycle. maybe I can borrow some of their scrap to practice on and then return it to them before they recycle it.
Robert
Posted: Wed Dec 12, 2018 9:08 pm
by cgaengineer
n3nman wrote:New to TIG welding and I have a good bit of scrap aircraft grade material (4130 and 7075-T6) but would like to get a good bit of 5052 or 3003 plus some mild steel for practise. Local in Atlanta. Anyone reasonable in the area. Already called a couple of "Steel" places without much luck. Someone needs to "sell" a coupon kit for beginners. Thanks
Try welding/fab shops...even here in Winder, GA we have many nearby.
Posted: Sun Aug 04, 2019 6:08 pm
by varekai
Go to weldmetalsonline.com, they all kinds of coupons and kits to practice with.
