Mike Westbrook
- Mike Westbrook
I just inherited an l-tec 250 hf plus stick and Tig machine stick works fine tried the Tig side no hf opened it up and the logic board looks like it got shot with a tracer round I suspect the hf filter failed letting high voltage back to the board so who do you guys recommend to get a replacement for the logic board and the capacitor filter board did a quick search found a place in ky called York that list it will call them tomorrow thanks for thoughts and suggestions in advance ......board number 675421 and filter number 680042
Mike Westbrook
- Mike Westbrook
Tried York was a no go sort of at a loss on this old girl if nothing else it's a 200 lb ac dc stick welder called esab and it's obsolete [emoji848]
Pete
Mike Westbrook
- Mike Westbrook
This one as well: http://welderpartswarehouse.net/ I had a Syncrowave years ago that needed a main board, 800.00 dollars later after the repair I found a company that rebuild or repaired them for $250.00 its been so many years ago I can't remember exactly which one it was, but there are a few out there that do this type of work.
Pete
Mike Westbrook
- Mike Westbrook
I have called dozens problem is they only repair them I sort of need another one
Och, Just a long shot but did you contact ESAB?
Pete
Mike Westbrook
- Mike Westbrook
I called Esab and they said the famous last words no longer available and it's a shame because the machine is in great shape it stick welds beautifully and it came with all the hoses Regulators 60 foot cables two air-cooled torches and a pile of tungsten my buddy's work was going to toss it in the metal bin so I've got nothing invested in it just a shame somebody's got one somewhere
Mike Westbrook
- Mike Westbrook
It does and I do I thought about that except the hf vaporized the solder and it's burnt in everywhere so it will conduct
I've only been looking for a week hopefully in time I'll find a good repairable one I don't need the machine right away it just has way more amperage than the little Tig I have and I have a soft spot for old overweight tranny machines
Hopefully you can find a board for it, it would make for a very nice welder.
Pete
