Nope. They're different alloys. But, a "clear" anodizing will change the nature of the material somewhat anyway. They will be close, and depending upon whether you're stitching panels together, or welding a tunnel/baseplate to a shell, the slight discoloration will not be noticeable.
Are you grinding the welds down? If so, that blending also helps with the discoloration differences. If you intend to leave the welds, then any difference only highlights the craftsmanship. (Moral of the story is: Be proud of your work and don't sweat the small stuff
![Cool 8-)](./images/smilies/icon_cool.gif)
Sounds good. I'm not worried about them mismatching a bit, I just wanted to make sure I wasn't going to have a bright seam and sepia panels or something of the like. I'll be blending the welds in, yes, and the whole reason I'm clear anodizing is to show the work anyhowcj737 wrote:Nope. They're different alloys. But, a "clear" anodizing will change the nature of the material somewhat anyway. They will be close, and depending upon whether you're stitching panels together, or welding a tunnel/baseplate to a shell, the slight discoloration will not be noticeable.
Are you grinding the welds down? If so, that blending also helps with the discoloration differences. If you intend to leave the welds, then any difference only highlights the craftsmanship. (Moral of the story is: Be proud of your work and don't sweat the small stuff)
I've heard of this. Is there an easy way to cut strips that are that thin? I'm using .063" sheet. I've got an air shear but the strips that it produces are like 1/4" wide.robtg wrote:A lot of M/C tank shapers use a strip of the parent metal for filler if they are going to polish.
I have never seen a M/C tank anodized.
kiwi2wheels
- kiwi2wheels
This might help you in selecting.
https://www.hobartbrothers.com/download ... i_1lOo.pdf
If you can find someone with a 48" manual shear ( Tennsmith, Jet, etc ) they could cut you 1/16" strips from your material.
- crashbandit
Check out the Alcotec website and search for the filler selection chart.
http://www.alcotec.com/us/en/support/Al ... -Chart.cfm
