Stainless 6G Question
Posted: Sat Oct 13, 2018 4:20 pm
So, I graduated welding school and have been searching for the right job since. 3 years of "job shops" as they call them around here have been decent work but not what I've been looking for. I finally got lined up for a test I've been looking for and it's a stainless 6g test on 2 inch pipe. In school I practiced 4 and 6 inch carbon pipe pretty good and did well. In the field I've picked up stainless no problem but I haven't done any purge work to prevent the "candying" on the inside. I am hoping that you guys might have some advice on that. And I'm all ears to advice in general. I'm hoping they'll supply legit purging equipment but I plan to bring tape and al foil just in case. I'm thinking to cover up any part that isn't about to be welded in every root pass and set the argon to 9ish on the purge. And for tacking the pipe together I was planning on taping everywhere other than where the tack would be. Is this the right technique? And anyone have any advice on letting the pipe cool inbetween passes? I got a heat gun I've used in the past and have been advised not to let test pieces pass 400 degrees and that worked well for me in the past but I'm not sure if it's overkill. This test is important to me and I have 2 weeks to prepare and am afraid I have nowhere to practice.
Thanks ahead of time!
