TIG Weld Aluminium - No Arc
Posted: Sun Aug 19, 2018 5:57 am
Experienced TIGgers I need your help........
Recently bought this;
https://www.welding.com.au/equipment...arc-200i-ac-dc
I am trying to teach myself but may seek out a local course depending on how it goes (not well so far!!).
I started out the first morning working with steel on DC. After some rubbish welds I did some not so rubbish ones. With more time I think I can easily iron out the issues and start having something presentable.
That afternoon I moved to aluminium on AC with HF start. I quickly had some butt joints happening although there was alot of variation in appearance (prettyness, width, height) that I struggled to understand fully. I started to get a slight feel for balance, frequency and amps though. Then.....without changing any settings the thing just would not strike an arc. When I pressed the torch button it would spit out a quick arc then immediately stop and try again (other forum posts seem to imply this is the HF?) - spat at around 2Hz. I cleaned the material even more (dedicated stainless steel wire brush), re-ground the tungsten for the millionth time, checked settings etc but no dice. I gave up.
This morning I have been at it again. I setup the machine from scratch, grabbed some fresh cleaned aluminium and viola it worked straight away (and quite reasonably.....maybe....see pic weld #1 below). I again welded away, changing some settings as I went so that I could see the results. Then after around about the same amount of welding the machine again started to not strike an arc!!! This time I can pin-point what I did before it 'failed'. The thin strips of aluminium were getting hot so I quenched it in some water then dried it off. I could not see water anywhere including in the butt joint area. Once I started welding again....no arc.
I think it would be easy to say that the water quench was the cause but I have some doubts as I dried thoroughly. Maybe it caused a huge amount of oxidation build up?
I have been struggling with keeping the tungsten out of the pool and with not pushing the filler rod into the tungsten. I am standing up which I am finding very uncomfortable for TIG (chair in design). I have re-ground the tungsten regularly on a brand new fine grinding wheel using the recommended technique.
I have noticed that the tungsten goes blue alot although I think I have fixed that by having more post flow and holding the torch in place until it cools. I seem to get a BIG ball on the tungsten sometimes which from what I can tell is not really a requirement on an inverter machine. Other times the point stays to some degree.
I don't want to jump down the path of this being a weld unit fault as I am new and don't know enough to go there. However, I am at a loss as to why the same thing happened after a similar duration and both times without any setting changes. The machine did not show either the voltage or over temp fault lights. At 77amps it has a 100% duty cycle and 15% at 200A so me welding around 90-110 I should have a high DC so that should not be the issue.
This second time I was able to get an arc to strike and hold ONLY IF I turned the balance up to at least 70% however once started the arc seemed to have little power and was not creating a weld pool. I had not touched the amp control but it was like it was running at much lower amps. Could be oxide related but I have wire brushed the heck out of the material and cleaned it afterwards with carby cleaner and still no dice.
I turned the machine off and went to have a coffee returning after maybe 15 minutes. I did not touch anything other than the on/off switch and........she worked perfectly. Now explain that!
I am at a loss and need suggestions. I realise you cannot fix things from the other side of the world but maybe somebody has seen this before or just knows what the cause is.
My settings at time of failure;
Frequency 119
Pre-flow 0.5s
Initial Amps 95
Ramp Up Time 2.0s
Amps 95
Ramp Down Time 4.0s
Crater Amps 50
Post-flow 7.0s
Balance 66%
Cup Size #6
Gas Flow 6lpm
filler rod 2.3mm
tungsten: 2% ceriated 1.6mm
stock 3mm
gas 100% argon
Not that I want to distract from my immediate issue but the welds in the pics are numbered in order. Ignore the area between 4 & 8 as they have been impacted by welds I ran on the back. An example of things changing when I don't understand why is that #1 and #2 I consider reasonable for a beginner but then the same settings results in #3 and #4 being flat and wide with #4 being very indented. My best guess is that the heat from the proceeding welds meant I should have lowered the amps for #3 and #4. There may have been some time passed by the time I got to #8 or maybe I changed the amps but it came out reasonable again. #1,2 & 8 had some weld material through the backside but not much in the way of full penetration (not sure if that is the goal with TIG on aluminium?).
Frequency 119
Pre-flow 0.5s
Initial Amps 95
Ramp Up Time 2.0s
Amps 95
Ramp Down Time 4.0s
Crater Amps 50
Post-flow 7.0s
Balance 66%
Cup Size #6
Gas Flow 6lpm
filler rod 2.3mm
stock 3mm
gas 100% argon
