What’s this called?
Posted: Sat Jul 28, 2018 1:00 pm
by Junior Welder
What’s this called? It is an adapter from my syncrowave 250 which connects the foot pedal to the pulser (miller pc-300) and the pulser to the syncrowave. If it’s not too expensive I’d like to buy a new one. If not I’ll have to resolder it since most of the connections broke
Thanks!
Re: What’s this called?
Posted: Sat Jul 28, 2018 1:02 pm
by Junior Welder
Other connection:
Posted: Sat Jul 28, 2018 2:38 pm
by Demented
Both ends of the adapter cable are male plugs? I've only seen them be male to female adapters. 5 to 14 pin plug adapters. Miller #13003 or #041947.
Posted: Sat Jul 28, 2018 10:04 pm
Resoldering is probably much cheaper and easier. Miller is real proud of there connecting cords, and they charg for it.
Posted: Sun Jul 29, 2018 9:30 pm
by Mike Westbrook
You can get those connectors on Amazon but they come from China only takes about 6 months to ship.... the 14 pins are very common the other dinse may match up to some aircraft ones
Posted: Mon Jul 30, 2018 4:32 pm
by Junior Welder
Thanks for the replies! Looks like I'll have to resolder. I found one at arc zone either for $50 or $150 but can't remember now. Too much either way.
No not both ends are male. I have two of those things, one from pedal to pulser and the other from pulser to welder, and I just happened to get both male ends for the pictures.
Thanks again
Posted: Mon Jul 30, 2018 5:07 pm
by Demented
That makes more sense. It's probably both those part numbers then.
Check out mouser or digikey if you want to make some new ones as spares. The plugs/sockets are only $5 or so and something like 10 cents for the pins.
