how can i correct my welding?
Posted: Mon Apr 16, 2018 5:54 pm
by yhanie
this is the machine that i used to weld aluminum.
Re: how can i correct my welding?
Posted: Mon Apr 16, 2018 10:06 pm
You can't use that machine for welding aluminium (very easily) as it is a DC mig/stick /tig. For learners and basic stuff you need an Ac/dc tig welder.
Posted: Tue Apr 17, 2018 12:32 am
by yhanie
hi mate,if cant use the machine to weld aluminum,can i use it for steel welding?
Posted: Tue Apr 17, 2018 2:31 am
by tweake
yhanie wrote:hi mate,if cant use the machine to weld aluminum,can i use it for steel welding?
yes its fine for welding steel.
Posted: Tue Apr 17, 2018 3:35 am
by yhanie
ok thanks mate,if i can use for steel this machine.can i use it also for stainless steel mate? i would be happy if i can use this machine :)
Posted: Tue Apr 17, 2018 4:37 am
by tweake
its fine with stainless.
Posted: Tue Apr 17, 2018 5:56 am
by yhanie
for car exhaust mate what kind of stainless this one? is this machine is ok for welding stainless forexhaust.pls see attachment thanks
Posted: Tue Apr 17, 2018 6:09 am
Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding. Aluminium requires AC cutting, the constant change of polarity is used to break down the aluminium oxide layer.
Posted: Tue Apr 17, 2018 6:46 am
by yhanie
ok mate thanks a lot for this one,,uve been helpful to me.ill try this machine to weld stainless steel.
Posted: Tue Apr 17, 2018 6:54 am
by Lightning
weldin mike 27 wrote:Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding..
If you tig the stainless, you'll probably have a better outcome with DC electrode negative, though...
Posted: Tue Apr 17, 2018 7:10 am
His statement was and steel can be TIG welded, plus the OP can weld anything set for DCEP. All DC TIG is set for DCEN, but the machine can also do DCEP.
Posted: Wed Apr 18, 2018 6:50 am
Damn. Sorry fellas. DC electrode Negative is it. Need to proof read better.
