Stainless Steel Beer Keg
Posted: Wed Nov 15, 2017 6:07 pm
by FitNPipe
I have a friend who wants a nipple welded in a stainless beer keg. I'm worried about sugaring the backside on something so thin. Is there a way to do it without a purge? I'm assuming I should pulse something that thin, any ideas of a starting point for amperage?
I've asked him for a piece of the scrap when he gets done cutting and fitting for me to try some things on too.
Thanks!
Re: Stainless Steel Beer Keg
Posted: Wed Nov 15, 2017 7:32 pm
There’s a product (I think it’s called Solar Paste) some here have used it you may be able to search posts for pictures of the results.
Posted: Wed Nov 15, 2017 9:35 pm
by thespian
Solar flux is what you need, but it will leave a grey glass like coating as it bakes in, and it isn't food safe.
Posted: Thu Nov 16, 2017 12:22 am
by Artie F. Emm
Can't be the first time anyone's ever pondered this. Can the nipple braze in?
Why not purge? Calculate the volume of the keg, add a Y connection to the flowmeter, run argon until the air is displaced, then weld?
Posted: Thu Nov 16, 2017 5:23 pm
by FitNPipe
I think I'm better off not being lazy and just going ahead and setting up a purge. Kind of thinking about buying a dual flowmeter.
Posted: Thu Nov 16, 2017 7:48 pm
FitNPipe wrote: Kind of thinking about buying a dual flowmeter.
HTP (USA Weld) has a economical dual flow meter, mine has been in service for about one year.
Posted: Thu Nov 16, 2017 9:16 pm
by Arclight Ironworks
@ FitNPipe - consider an alternate approach. Silver (4-6%) Soldering. If you do elect to apply traditional TIG the fuse the assembly, def practice-learn-practice-learn- - prior to arclight on the actual keg. Common wall thicknesses for Sankey style SS kegs are 14 ~ 18 gauge. Fitup needs to exacting for best results.
Vid of a brewing fabricator using silver solder and Tri-Clover fittings.
https://youtu.be/_NkHlDql8EU
Posted: Sat Nov 18, 2017 8:48 am
by Bill Beauregard
I bought a T. For a time I stole the flow meter off the MIG for purging. Stainless welds very nice once you solve the purge issue. I have Solar Flux, I have not been totally successful using it.
Willie
Posted: Tue Dec 26, 2017 12:51 pm
by Mihtu
I have done this many times on brew kettles. I used stay silver solder with stay brite flux,first we drew a stainless reducer through the hole to get it to pucker from the inside,it leaves a nice little well on the inside for the solder to set in,then pre wrapped solder rings over the nipple,the fluxes it,and heated ot till the solder flowed,it has worked great for many batches!
