I have a friend who wants a nipple welded in a stainless beer keg. I'm worried about sugaring the backside on something so thin. Is there a way to do it without a purge? I'm assuming I should pulse something that thin, any ideas of a starting point for amperage?
I've asked him for a piece of the scrap when he gets done cutting and fitting for me to try some things on too.
Thanks!
Artie F. Emm
- Artie F. Emm
Can't be the first time anyone's ever pondered this. Can the nipple braze in?
Why not purge? Calculate the volume of the keg, add a Y connection to the flowmeter, run argon until the air is displaced, then weld?
Dave
aka "RTFM"
aka "RTFM"
- Arclight Ironworks
@ FitNPipe - consider an alternate approach. Silver (4-6%) Soldering. If you do elect to apply traditional TIG the fuse the assembly, def practice-learn-practice-learn- - prior to arclight on the actual keg. Common wall thicknesses for Sankey style SS kegs are 14 ~ 18 gauge. Fitup needs to exacting for best results.
Vid of a brewing fabricator using silver solder and Tri-Clover fittings.
https://youtu.be/_NkHlDql8EU
Bill Beauregard
- Bill Beauregard
I bought a T. For a time I stole the flow meter off the MIG for purging. Stainless welds very nice once you solve the purge issue. I have Solar Flux, I have not been totally successful using it.
Willie
Willie
I have done this many times on brew kettles. I used stay silver solder with stay brite flux,first we drew a stainless reducer through the hole to get it to pucker from the inside,it leaves a nice little well on the inside for the solder to set in,then pre wrapped solder rings over the nipple,the fluxes it,and heated ot till the solder flowed,it has worked great for many batches!
