oki270
    Sun Dec 25, 2016 8:04 am
Hello all,
newbie here so please be gentle :). I'm trying to make a balcony fence out of stainless steel 304 tubes (diameter 4 cm - 1.5", 1/16 wall ticknes / no backpurge / using 308 filler / around 45 Amps). The problem I have are angle joints (90 degrees) - as expected. Even though I don't overheat the tubes (at least I think so - no black areas) I still am unable to keep 90 degree angle whichever welding sequence I use. Keep in mind that I'm able to weld 1/4 of a tube in one shot. Please help how to get at least semi-decent angle after welding.
Edit; forgot to add - I always get an angle smaller than 90 degrees / I always make 4 tacks on all "4 sides"
It could be you're just simply not using an adequate welding sequence. If you elaborate on which ones you *have* used, then I'm sure soneone will be able to point out important considerations.
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
https://www.youtube.com/watch?v=chUOzYmxOH4
Jody starts on the outside edge and welds that. Maybe the video will help a little.
oki270
Oscar wrote:It could be you're just simply not using an adequate welding sequence. If you elaborate on which ones you *have* used, then I'm sure soneone will be able to point out important considerations.
Last one I tried - 4 tacks - 90 degrees apart. After tacking still 90 degrees as required. After outside 180 degrees I still have 90 degrees between pipes. Then when I do inside 180 degrees, I pipe gets pulled inward so inside corner gets to cca 80 degrees :(. Any ideas?
I watched Jody's video on stainless square tubing and I do get pretty good corner on it but round one appears a bit more difficult and still cannot get it right :?
    Sun Jan 15, 2017 1:08 am
One cheat you can do is cut them slightly less of an angle so after welding it pulls itself to 90
When I use to do pie cuts we had them all laser cut I would sand the outside edge a little more then the inside when I was removing the dross.
Sent from my XT1635-01 using Tapatalk
dgapilot
    Wed Jul 26, 2017 7:00 pm
Try welding 90 degrees, not 180. Let it cool between welds. Use some scrap to come up with the sequence with the least distortion, then adjust your fit up so when it shrinks, it stabilizes at 90 degrees
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
    Wisconsin
