Heat input
Posted: Fri Sep 29, 2017 3:10 pm
by pfoley
Which process puts less heat input in the materiel and why?
Re: Heat input
Posted: Fri Sep 29, 2017 10:14 pm
Not welding anything is by far the clear winner. :lol:
Re: Heat input
Posted: Fri Sep 29, 2017 11:32 pm
by MinnesotaDave
Oscar wrote:Not welding anything is by far the clear winner. :lol:
Cold fusion for the win :D
Re: Heat input
Posted: Sat Sep 30, 2017 3:12 am
by noddybrian
JB weld is the least heat input I know of !
Re: Heat input
Posted: Sat Sep 30, 2017 8:44 pm
by pfoley
Really which one out of tig, mig, or stick is better for less distortion?
Re: Heat input
Posted: Sat Sep 30, 2017 8:50 pm
pfoley wrote:Really which one out of tig, mig, or stick is better for less distortion?
The reason these responses cone out is because of very general qiestion that that are missing many important parameters. While heat input can be associated with distortion, joint fixture'ing and geometry has a lot to do with distortion in the finjshed oroduct as well.
Re: Heat input
Posted: Sat Sep 30, 2017 9:48 pm
Oscar wrote: The reason these responses cone out is because of very general qiestion that that are missing many important parameters. While heat input can be associated with distortion, joint fixture'ing and geometry has a lot to do with distortion in the finjshed oroduct as well.
As well as material...
Re: Heat input
Posted: Sat Sep 30, 2017 9:58 pm
by pfoley
Let's say I'm using the same settings for all three processes and the same thickness material?
Re: Heat input
Posted: Sat Sep 30, 2017 11:49 pm
by MinnesotaDave
pfoley wrote:Let's say I'm using the same settings for all three processes and the same thickness material?
Can't use the same settings for mig, tig, stick...
You will get a lot better responses if you show pics of what you are trying to do.
