pfoley
    Fri Sep 22, 2017 10:49 pm
Which process puts less heat input in the materiel and why?
Not welding anything is by far the clear winner. :lol:
    Sun Oct 27, 2013 10:57 pm
Oscar wrote:Not welding anything is by far the clear winner. :lol:
Cold fusion for the win :D
    Thu Jan 24, 2013 12:13 pm
JB weld is the least heat input I know of !
pfoley
Really which one out of tig, mig, or stick is better for less distortion?
pfoley wrote:Really which one out of tig, mig, or stick is better for less distortion?
The reason these responses cone out is because of very general qiestion that that are missing many important parameters. While heat input can be associated with distortion, joint fixture'ing and geometry has a lot to do with distortion in the finjshed oroduct as well.
Oscar wrote: The reason these responses cone out is because of very general qiestion that that are missing many important parameters. While heat input can be associated with distortion, joint fixture'ing and geometry has a lot to do with distortion in the finjshed oroduct as well.
As well as material...
pfoley
Let's say I'm using the same settings for all three processes and the same thickness material?
pfoley wrote:Let's say I'm using the same settings for all three processes and the same thickness material?
Can't use the same settings for mig, tig, stick...
You will get a lot better responses if you show pics of what you are trying to do.
