rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
Can using too big of a cup.....say 3/4" with a gas lens.....compared to a 1/2.......with a gas lens......be detrimental to the weld?
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
rahtreelimbs wrote:Can using too big of a cup.....say 3/4" with a gas lens.....compared to a 1/2.......with a gas lens......be detrimental to the weld?
In most cases I say NO, just an increase in coverage or wasted Argon.
dirtmidget33
    Tue May 13, 2014 5:22 pm
Larger cup not gonna hurt anything just creates larger inert atomsphere around weld. It can help give you better color on welds do to coverage staying on area until it cools longer as you move. However larger cups require more flow and if weld doesn't really need the extra coverage it's just a waste of argon.
    Thu Jan 24, 2013 12:13 pm
I can't think of any situation a bigger cup size is'nt better !
kiwi2wheels
    Sun Feb 17, 2013 10:27 am
I had an instance where I was plugging some holes in an aluminum rad tank with some 1.2 x 18mm diam discs into the hole from a 20mm tube, which had been hit with a 90 deg counter sink to locate the disc.
Using a #6 cup with a gas lens was a PITA, always burning the disc back, and this was being done on a bench , so there was no access problem, re torch angle.
Changed to a plain # 5 cup, three tacks and weld, finish. I'd sure like to understand why !
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
noddybrian wrote:I can't think of any situation a bigger cup size is'nt better !
Never really hurts. Only time is if it had to be small to fit somewhere. Really, you can't ever get enough gas coverage for the most part. Too much can cause problems of blowing out the weld but...
Were we still talking about welding - sorry - my bad - mind must have wondered !
    Thu Dec 25, 2014 9:25 am
    near Chicago
noddybrian wrote:Were we still talking about welding - sorry - my bad - mind must have wondered !
You too?
    near Chicago
Jody suggests that a smaller standard collet body and cup can work better for Aluminum. Has anyone ever tried it? Once I put on a gas lens, I never took it off but I just watched one of his vids and he says it and so does Roy Crumrine.
I too tended to leave a gas lens on with a 7 or 8 for everything but had to switch back to a standard length 5 for access on an aluminum casting - cannot explain how but it creates way more etch zone / cleaning action for the same AC balance - after realizing this I found you could run less cleaning on the balance & give the tungsten an easier life - also when crap boils out / explodes it does'nt ruin anything - just scrape the ceramic clean if it builds up - not like gas lens mesh so I now use standard collet body for aluminum - found this out by accident a while back - then saw Jody recommend it so if it's good enough for him it must be right.
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
kiwi2wheels wrote:I had an instance where I was plugging some holes in an aluminum rad tank with some 1.2 x 18mm diam discs into the hole from a 20mm tube, which had been hit with a 90 deg counter sink to locate the disc.
AC only cleans where there is argon coverage, so better coverage over a wider area leads to a wider weld with a wider cleaning zone for a given amperage.
That makes perfect sense in theory but I seem to get a wider cleaning band from a regular collet #5 than a #7 or #8 gas lens for the same balance setting which makes no sense at all - I can actually go slightly more EN & get the same etch zone using a standard #5 so that's what I use now - I don't understand why though - only swapped out due to contamination originally - guess when you find something that works stick with it even if it defies logic / instinct.
exnailpounder wrote:Jody suggests that a smaller standard collet body and cup can work better for Aluminum. Has anyone ever tried it? Once I put on a gas lens, I never took it off but I just watched one of his vids and he says it and so does Roy Crumrine.
I use an #8 Pyrex and gas lens mostly, but swap to a collet body and #5 for tight spaces or small pieces/thin pieces. The #5 is small enough that gas flow doesn't really see the turbulence of a larger diameter cup so the gas lens isn't as differentiated. My input.
I use standard alumina cups size 5-7 for almost 99% of stuff at home and at work. I have gas lens cups and standard ones up to about 12 but don't use them much.
kiwi2wheels
It was near impossible to make a run between the tacks with the gas lens set up. The arc would always migrate to the disc, like welding on steel too close to a magnet. I was more or less making a series of tacks and then pulsing over them.
It was the first inverter machine I'd used, but the other alu jobs (extrusions, castings, etc) hadn't been a problem with gas lens.
