Helium And Added False Amps???
Posted: Sun Mar 26, 2017 8:56 pm
by rahtreelimbs
When you add a Helium mix to your argon is there a rough calculation on how many simulated amps you gain?
Re: Helium And Added False Amps???
Posted: Sun Mar 26, 2017 9:00 pm
Interesting question. I'm not sure how one would quantify it, short of advanced mathematics to give theoretical values. I have used helium mixes (in approximate quantities from two flow-meters) and can't even give you a rough guess.
Posted: Sun Mar 26, 2017 9:19 pm
by rahtreelimbs
Otto Nobedder wrote:Interesting question. I'm not sure how one would quantify it, short of advanced mathematics to give theoretical values. I have used helium mixes (in approximate quantities from two flow-meters) and can't even give you a rough guess.
Steve I know a ballpark quess is there somewhere.
The reason I ask......If you look at my thread "How Nice It Is" I am tig welding 1/4 aluminum. I was using my HTP 221 Invertig. Amperage was maxed out at 220. The whole process was a learning experience. I had to hold longer to establish a puddle......and i had to hold between dabs to keep the puddle fluid. It all worked.....just took longer. I don't do much over 1/8" aluminum.
Posted: Sun Mar 26, 2017 10:12 pm
I'll throw a rough guess of 25-30% at a 50/50 mix, but that's merely a guess. At 30%, that would be another 66A, in your case.
I never tried to quantify it before. I only used it when I got to 1/2" sections where pre-heat alone would not be sufficient with 310A max capacity at 10% duty.
Posted: Sun Mar 26, 2017 10:33 pm
I welded up a table base of 3x3x0.25 steel this weekend. Using straight Argon, I was running 180 amps. Bottle was pretty low to start the day, and ran out with about a quarter of the job left. Swapped in a 75/25 Helium mix and ran the balance of the welding at 140 amps. I did adjust the flow up by about 5cfh based upon color of the tungsten while workin, but the welding went smooth as butter with the added He and lowered amps.
