nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
Anybody know of a solution to pretty up 6061 after fabrication?
If there isn't anything I'll have to flap sand them. Is WD-40 the way to keep the sandpaper from clogging?
Rudy Ray
    Tue Jan 24, 2017 7:36 pm
    Fresno, California
red "scotch-bright" if you have to do it mechanically.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Alu- brite is the way to go. And then soapy water.
    Thu Dec 25, 2014 9:25 am
    near Chicago
Barkeepers Friend. I use it to repassivate SS. Does wonders on copper. Bet it would work on AL.
Are you trying to polish it to have some luster or are you trying to remove the white etching zone from the cleaning action?
Troy Boy 72
    Thu Dec 31, 2015 7:22 pm
    Mackay North QLD
Hey Mate, I'm with Mike ALU BRITE for clean up works very well and soap for your sandpaper stops ally clogging it up not real sure what it is made of just comes in a foil tray from my LWS . I think Jody mentioned in a recent video he used some shower soap .
Cheers Troy
nelson
    near philly
Thanks for the suggs. I just started fabbing more with Al since I have the way to weld now.
I'm just going for pretty. 6061 has that dull look from the mill. I want that scotch Brite look all over. I'll definitely get some alu-brite.
I do wood work too. It's always the finishing I try to sidestep.....work..ug.
Thanks again!
nelson
    near philly
I'm not seeing alu Brite available in this 3rd world USA country...I'll keep looking.
nelson
    near philly
Eagle One Etching mag cleaner....on Amazon. Looks like it's strong enough. Feedback says it does etch the surface.
nelson wrote:I'm not seeing alu Brite available in this 3rd world USA country...I'll keep looking.
aluma brite
or
aluma kleen
    Mon Feb 09, 2015 4:48 pm
    St. Johns, Michigan
Eagle has worked for me in the past, I use it to remove oxide layer prior to welding.
nelson wrote:Eagle One Etching mag cleaner....on Amazon. Looks like it's strong enough. Feedback says it does etch the surface.
Pete
nelson
    near philly
Thanks pgk, that's great. I buy stuff that doesn't work way too often.
Keith_J
    Tue Dec 20, 2016 1:55 am
    Central Texas
I spilled some prep and etch ( phosphoric acid for rust removal) on aluminum and it shined up nicely. Cheap at Home Depot.
