Couple of pipe repairs
Posted: Sun Feb 19, 2017 10:40 pm
by Coldman
This first pipe I believe was installed by a basket weaver, badly on the piss. I had to put in a 4" dogleg to straighten it out and relieve the pressure on a flanged control valve. 1" sched 40.
- R1.jpg (55.56 KiB) Viewed 1420 times
Second pic is replacing a section of rusted 1/2" sched 80 pipe, about 12ft up, frustrated access on one side, treated sump water dripping down onto pipe caused my bead to freaking explode a couple of times just as I was sealing it up. I think the chemicals were crystallising into the joint causing some kind of contamination. Cut and grind.
- R2.jpg (131.92 KiB) Viewed 1420 times
Ferkin hot and humid heat wave that day. Beer o'clock saw me chewing cans rapidly.
Re: Couple of pipe repairs
Posted: Tue Feb 21, 2017 9:24 pm
by Rick_H
Nice repair! So that pipe was stressed 4"!!!!
Posted: Tue Feb 21, 2017 10:01 pm
by Coldman
Yep. I should've taken a before pic. Out 4" in two directions. Discovered when the solenoid valve was removed for service and the pipe sprang apart. There must have been huge force on the valve casting and flanges all that time. Absolute awful and dangerous original install. The welding done on it makes you spit as well.
Posted: Wed Feb 22, 2017 7:16 am
by exnailpounder
Amazing that they let hacks work on something that could be so dangerous if a failure ever occurred. Now they have the right man on the job. Nice work!
Posted: Wed Feb 22, 2017 7:22 am
by motox
must have been scary when you separated it,...
Posted: Wed Feb 22, 2017 10:16 am
by Notapro
What process did you use when welding it back together? Nice fix, I like the clamp attachments, Do you use them frequently?
Posted: Wed Feb 22, 2017 7:25 pm
by Coldman
All butts were tigged in two passes with vee prep, no land and 3/32" wire gap.
Both clamps are stronghand tools commonly used by pipe welders to align pipe joints.The lower one comes in two sizes, this one is the small vice grip clamp and is good down to 1" pipe. It grips 3/4" & 1/2" pipe but not enough gap is left between the jaws to get a tack in. The upper c-clamp has one v-mag jaw only, a little bit fiddly to get the alignment right but leaves a gap even on 1/2" pipe to tack through.
I use these clamps all the time, great time saving tools that gets the all important alignment right.
@craig
I believe the the comments when the the pipe sprung apart were something like " oh snap, that's something you don't see everyday!" followed by a brief discussion concerning the lineage of the original welder.
Posted: Wed Feb 22, 2017 8:20 pm
by exnailpounder
Coldman wrote:All butts were tigged in two passes with vee prep, no land and 3/32" wire gap.
@craig
The lineage of original welder was the first question I asked myself.
Posted: Wed Feb 22, 2017 8:27 pm
by Farmwelding
What was the lineage of this welder you speak of.
Posted: Wed Feb 22, 2017 8:32 pm
Farmwelding wrote:What was the lineage of this welder you speak of.
Maybe something to do with knuckle dragging?
Posted: Wed Feb 22, 2017 8:33 pm
by Coldman
We can only speculate cause we don't know his identity
Sent using Tapatalk
Posted: Wed Feb 22, 2017 8:39 pm
by Farmwelding
Coldman wrote:We can only speculate cause we don't know his identity
Sent using Tapatalk
Probably better this way. If you found out who he was he might have a problem coming his way from you.
Posted: Wed Feb 22, 2017 9:15 pm
by exnailpounder
LtBadd wrote:Farmwelding wrote:What was the lineage of this welder you speak of.
Thats' what I call "bad welders"
Probably learned pipefitting from his uncle Dad.
Posted: Wed Feb 22, 2017 9:20 pm
by MinnesotaDave
Otto Nobedder wrote:Probably learned pipefitting from his uncle Dad.
Bahahaha!!
by Coldman
Posted: Wed Feb 22, 2017 10:04 pm
by Farmwelding
Is there a Kentucky in every country.
no offense to any from Kentucky.
Posted: Wed Feb 22, 2017 11:03 pm
by Rick_H
Farmwelding wrote:Otto Nobedder wrote:Probably learned pipefitting from his uncle Dad.
I live in Pennsyltucky
Posted: Wed Feb 22, 2017 11:35 pm
by GreinTime
Rick_H wrote:Farmwelding wrote:Otto Nobedder wrote:Probably learned pipefitting from his uncle Dad.
At least you don't live in Fayettenam
Posted: Sat Feb 25, 2017 2:10 am
by bigfabdaddy
Steve S[/quote]
no offense to any from Kentucky.[/quote]
[/quote]
Sent from my VS995 using Tapatalk[/quote]
I'm about 61 miles east of you.
