FizHD
    Tue Sep 13, 2016 8:03 pm
    Westport, IN
Greets!
Just started playing with aluminum a couple days ago. Stacking beads basically.
[img]
[/img]
Got together with a couple of our county neighbors Friday for dinner and cards and mentioned that I was practicing welding some aluminum. One of them said he had a miter saw that had a broken piece and wanted to know if I could weld it. He told me that I couldn't hurt it. It's the blade shield mount. I said no guarantee but would be glad to try.
After watching a couple videos and reading a bit I decided to give it a try.
Here it is.
[img]
[/img]
Attached
[img]
[/img]
It doesn't appear by the preview that my pics are in the right spot. Oh well...
All comments welcome!
Thanks for looking,
John
LE 210MP
LE 200 TIG
Evolution Rage3
    Thu Dec 25, 2014 9:25 am
    near Chicago
Nice work.
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Welcome.
If you've just started with aluminium and your first job is cast, you've done well. Any details you can share regarding settings, filler, all that?
Kym
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
welcome to the i can weld neighborhood.
you will be popular friends and neighbors
now...lol
nice fix!
FizHD
    Westport, IN
Thanks!
Pretty much all my welding knowledge is from watching Jody. Thanks man!
Setting for saw repair:
Running a LE tig 200
15CFH with gas lens and #7 cup.
3/32" tapered 2% lanthanated electrode extended due to position.
3/32" 4043 Harris filler.
Parts and rod wiped with acetone.
125 A
No pulse.
Started on 70% EN moved to 65 after the first tack.
Freq was 100 to start, moved to 150 after first tack.
I ran across the area letting the cleaning action work before welding.
John
LE 210MP
LE 200 TIG
Evolution Rage3
    Tue Dec 13, 2016 9:24 pm
    Clearwater Florida
FizHD wrote:Thanks!
125 A
No pulse.
John
Not bad at all.
Most tungsten for A.C does not have to be tapered as it will ball by itself, I have sharpened them for very fine, precise welding but they ball so fast I find it pretty much pointless.
How many times did you run over your bead after you laid it?
FizHD
    Westport, IN
Olivero wrote:
FizHD wrote:Thanks!
125 A
No pulse.
John
Not bad at all.
The tungsten has been staying fairly sharp for me. Not really balling at all.
I basically heated the base to slight puddle and added a bit of rod. Then smoothed it out a bit. I did 5 dabs resting in between each one for a couple minutes to cool. Then start a new spot and flow to the previous. Didn't really know what to expect lol
I wasn't concerned with cleaning up the weld because it's under a cover. I figured I would leave the bead for strength.
John
LE 210MP
LE 200 TIG
Evolution Rage3
    Clearwater Florida
FizHD wrote:
Olivero wrote:
FizHD wrote:Thanks!
125 A
No pulse.
John
Not bad at all.
John
Ah, got ya.
Well, the tungsten will normally ball after a bit of welding, really not important in this case, just thought I would mention it as you will run into it eventually and it is normal.
Looks like you went over the bead a time or 2 after having put it down, just curious.
