Tig Brazing practice
Posted: Thu Jan 12, 2017 8:31 pm
by JHenze646
I am self-learning hobbyist.
I would like to Tig braze some engraved aluminum plates to the steel bases of some gifts I am making. It will be a 4 side lap joint.
My question is: Since I already don't know what I am doing with welding, are there any specific considerations for tig brazing I should be aware of? Also are there any specific drills or practices that will help with learning this in particular?
The Al is 10 gauge, the steel is 3/16, I am using silicon bronze, and I am welding with a Powerarc 160STH.
Thank you in advance for any help you can offer.
Re: Tig Brazing practice
Posted: Thu Jan 12, 2017 10:44 pm
by zank
No go. The melting point of silicon bronze is about 1800F and the melting point of aluminum is about 1100F.
Posted: Thu Jan 12, 2017 11:36 pm
by JHenze646
Thank you.
Ok, I am changing the plan, not the goal. I will have to engrave a steel tag.
My first try with silicon bronze did not go well. I tried a bead on plate and it looked all granular and didn't wet out.
Any help is appreciated.
Posted: Fri Jan 13, 2017 1:56 pm
by hey_allen
Is it possible to use aluminum bronze (ERCuAl) brazing rod on aluminum plate, or is the bronze component high enough temp that it will still be above the pure aluminum?
Posted: Fri Jan 13, 2017 2:22 pm
by zank
Aluminum bronze melts at about 1900F.
Posted: Sat Jan 28, 2017 11:11 am
by JHenze646
- 0128171000.jpg (48.9 KiB) Viewed 1314 times
So this isn't going well. The filler rod balls up, the bead is granular looking, and it only seems to wet out if I am melting the base metal.
I am using 1/16th filler rod and the base plate is 3/16.
Posted: Sat Jan 28, 2017 11:19 am
by electrode
Posted: Sat Jan 28, 2017 11:50 am
by exnailpounder
You're including your base metal into your braze. Tig brazing takes practice. You have to use an amperage that would eventually puddle your base but will melt your braze long before your base. takes practice.
Posted: Mon Feb 20, 2017 12:11 am
by JHenze646
Things are getting a little better but I am still melting base metal into my braze. I switched to using the torch switch but even at 40 amps the 1/8th inch steel is melting. These were just scrap pieces. I plan to just keep practicing.
As always any help is appreciated.
