Hi everyone! A quick introduction. Started with TIG welding 3 years ago. At first it was only carbon steel pipes with some stainless last year. For the last 5 months I've been welding only 304 and 316 SS with some aluminum here and there. It's a relatively big workshop, but there are only two weldors. Everything else is manual machining and CNC work. So I come across a lot of things: small delicate parts, big contraptions for food processing, big thin wall pipes, sheet metal welding... It has been a really steep learning curve for me, with lot's of mistakes to learn from.
Next year we'll have lot's of big parts made out of Duplex. 5 mm to 13 mm thick, machined and cut, everything should be welded with corner welds. It's a standard Duplex, 2205 variety. But, I have never worked with Duplex. I have found a lot of general information about Duplex from a metallurgical standpoint, but I need to know how to weld it.
What considerations for Duplex welding I should know about, compared to 316 SS, for example? I'm sure there are a lot of weldors on the forum who have welded Duplex, so any information would be really appreciated.
Cheers!
It sounds as though the duplex parts are not pipe, so I am assuming your not welding for full penetration. I use to do duplex pipe and we'd use Ar/3% Nitrogen mix for the purge gas.
This site has a 68 page PDF file that includes a section on fabrication, should answer your questions.
Scroll down about half way and look for the publication "Practical Guidelines for the Fabrication of Duplex Stainless Steels "
and download the pdf
Right, no pipes for now. Just thick plates, big rods and machined parts. Thank you for the link. Hopefully I would find what I need.
Aside from the purging gas and filler rod, what did you do differently when welding Duplex pipes, compared to 316 SS?
