Foot pedal and amperage control
Posted: Sun Jan 16, 2011 5:38 pm
by racingparts
Hello again guys
i just purchased 2 weeks ago the foot pedal (7 pin connector) for my welder and i have a few questions.
i use pulse almost every time i weld ..so when i use pulse ..i don’t get any amperage control, it’s just like when i use the torch switch, ON-OFF effect. Is this normal? this is the way it works?
i only get amperage control when i don‘t use pulse, i set the amperage on the machine at let’s say 90 amps maximum ..and with the pedal i start and increase my amps or decrease if needed.
On the pedal i have an max current adj. nob ..from 1 to 10
i keep it at 8-9 when i use it.
Please if there are any tips in using the foot pedal ..enlighten me
Re: Foot pedal and amperage control
Posted: Mon Jan 17, 2011 5:57 pm
by kermdawg
Yes and yes.
Never seen a foot pedal with a adjustment knob on it so I can't help you with that. What I would do is get some scrap, put it at 10 and run a bead, then put it at 1 and run a bead and see what the differance is.
Posted: Mon Jan 17, 2011 9:57 pm
by WILD BILL
Is that for an Everlast welder?
If so have you asked on the Everlast forum?
http://www.everlastgenerators.com/forums/
Posted: Mon Jan 17, 2011 10:18 pm
by amurrow
You should still have foot pedal amperage control regardless of pulse settings. Sounds like something the manufacturer should help you with.
Posted: Tue Jan 18, 2011 3:02 am
by racingparts
are you sure about that?
a pulse setting needs you to set the values ...background current ..and pulse current ..
how could you still have amperage control ..and pulse?
Posted: Tue Jan 18, 2011 5:17 pm
by sschefer
racingparts wrote:are you sure about that?
The background current and pulse current settings represent percentages of the Max current that your regulating with the foot pedal.
Posted: Wed Jan 19, 2011 3:00 am
by racingparts
it’s obvious that my pedal is crap
or my machine too
Posted: Fri Jan 21, 2011 3:10 am
by racingparts
i think my welder is following the forums
as soon as i wrote above ..it started working
now i have amperage control with pulse ...but when i push the pedal for more and more amperage ..the pulse suffers some changes..it-s not that obvious as at lower amps.
anyway i ordered a new quality component (potentiometer) for my pedal ..to change the chinese one i have inside
maybe it will work even better
