i have a job on where I am welding 40x10mm and 60x10 aluminium flat bar together for a balustrade, I am trying to get a really fine weld, so I started using a 1.6mm electrode, it starts off alright but after about 8 seconds the electrode explodes.
I am running 230 amps , does anyone know why ? are the amps to high maybe ?
The amps are like WAY too high. You should be using 1/8" tungsten...3/32" at the very least and even that is arguable. 150is about the max on 1/16" Welcome to the forum and good luck on your project.shannon1964 wrote:i have a job on where I am welding 40x10mm and 60x10 aluminium flat bar together for a balustrade, I am trying to get a really fine weld, so I started using a 1.6mm electrode, it starts off alright but after about 8 seconds the electrode explodes.
Hahaha! Not sure how that didn't go catastrophic on you instantaneously.
3/32" lanthanated handles 225A ac @ 30% cleaning in my #20 watercooled torch just fine for two minute runs. Never tried to push it any further.
Raymond
Everlast PowerTIG 255EXT
If you're trying to "shrink" the size of your weld bead and get a "fine" weld, as in much more narrow, you can't accomplish that by simply dropping in size for the tungsten it just doesn't work that way. Smaller diameter tungstens do not focus the arc better than a larger diameter tungsten. The shape of the grind profile does have an effect, however. Also, using a very high AC frequency (if your welding machine offers it) can often provide the greatest change when trying to get a fine, narrow bead. But not all welding machines have a very high AC welding frequency capability.
shannon1964
- shannon1964
thanks guys, I went back to a 2.4mm electrode ( much better ) and turned up the Hz to 60, my machine ( unimig 315 ac - dc )maxes out at 70 . I really appreciate all of your feed back to. cheers.
