Tugnsten marking(s)
Posted: Sat Oct 22, 2016 7:29 pm
by Corvax7
Hey, my name is Aaron and I have a question. I am a student at my local technical college and the tugnstens I use for Tig welding go in out and all around when I am using then. I have noticed the colored markings is starting to wear off and it is becoming hard to individually identify them. I would like to know if any of you are having this problem and is you have found a solution to a special way to mark tugnstens. Marking with a file? Special heat-resistant paint? I don't know but mabe you will.
Re: Tugnsten marking(s)
Posted: Sat Oct 22, 2016 7:40 pm
by Coldman
Best way is to keep them separated preferably in original packet.
Posted: Sat Oct 22, 2016 10:40 pm
I only use one kind for almost everything. Those I keep togeather mixed in one case. Anything else I put back in its pack like Cold said.
Posted: Sun Oct 23, 2016 1:22 am
by Tom Osselton
You could grind a notch or sharpen both ends each different from the other.
