Re: scotch briteing tungsten?
Posted: Mon Aug 22, 2016 5:18 pm
http://www.thingiverse.com/thing:18347
This is a 3d Printed tungsten grinder that has 4 fixed positions for the various tungsten sizes.
Per Jag (the designer):
This is an attachment for a dremel or similar tool that makes it easy to grind tungsten electrodes for TIG welding.
It has holes for 1/16", 3/32" and 1/8" electrodes at 4 different angles.
I'm using it now on my dremel using the "TEMO 10p solid 1.5" 40mm Diamond Coated Cutoff wheel disc 1/8 shk for dremel" I found on Amazon per one of the users' who tried this thing out. It does a nice job at grinding the tip down and the fixed positions ensure your tungsten never jumps off the grinder! WIth the 6 discs it gives you, you can have a separate wheel for almost all the material/rod you'll be working with. Pretty snazzy!
Here's a user's thread on here that used this:
http://forum.weldingtipsandtricks.com/v ... f=5&t=8813
I'll be playing around with the results from a clockwise vs. counter-clockwise twist to see if my random question about the hemispheres of the earth playing a part in the arc control but I could never test that theory without a tungsten grinder, and with this I didn't spend $300-800 on one
Yeah probably thinkin too deep on the hemispheres but it clearly changes the way hurricanes twist so it's something else for me to play with. It's called Coriolis force in case you forgot ( I did).
