Page 108 of 131
Posted: Sat Jul 08, 2017 6:11 pm
by Bingo
Ok this one was not today but I wanted to share it. This was at a nuclear plant on the turbine deck (so no radiation that's why I had my phone)
Posted: Tue Jul 11, 2017 4:10 pm
by pgk
Awesome work Sam...
Posted: Tue Jul 18, 2017 11:14 pm
by 5th Street Fab
Welded this today.
This will have a big tower mounted on top like the last one I built. They wanted it to hinge on 2 small brackets, but there's no way it old hold plus the brackets were way off so I built a doubler and gussets.
This will be really cool when it's done I'll show you guys later hopefully.
Posted: Thu Jul 20, 2017 4:37 pm
by BigD
Keep forgetting to post my experiences with SolarFlux. This stuff is gold if backpurging stainless isn't reasonable or practical. I use it with ISO alcohol, works GREAT!!!
- IMG_6212.JPG (89.88 KiB) Viewed 4095 times
Posted: Thu Jul 20, 2017 5:10 pm
Did you butter up the two halves before or after you tacked them up?
Posted: Thu Jul 20, 2017 5:13 pm
Woo hoo !! Just found out the paper work went through and I get to take my weld test for my R stamp next week.
Posted: Thu Jul 20, 2017 11:26 pm
by Coldman
Awesome! Good luck with the test Josh!
Posted: Fri Jul 21, 2017 1:07 pm
by BigD
Poland308 wrote:Did you butter up the two halves before or after you tacked them up?
After, I tried to keep the tacks shallow. I didn't clean it all up since it's just an exhaust pipe but I wiped off an area with acetone and it's nice and shiny metal underneath.
Posted: Fri Jul 21, 2017 4:44 pm
Cool! I was wondering if it would interfere with the weld process if it was worked down into a crack. I'm envisioning that you might be able to coat the two sides before you tack up. If there was no way to get at the joint after fit up.
Posted: Fri Jul 21, 2017 7:08 pm
by GreinTime
Another flex from the other day
Posted: Tue Jul 25, 2017 4:15 pm
by pgk
Great looking weld Sam
Posted: Tue Jul 25, 2017 6:53 pm
by GreinTime
pgk wrote:Great looking weld Sam
Thank ya kindly!!!
Posted: Wed Jul 26, 2017 8:56 pm
by GreinTime
Some Subaru intercoolers, and some 9th Generation Honda Civic Turbo Manifolds
Posted: Thu Jul 27, 2017 7:24 am
by MosquitoMoto
That is some beautiful work!
Moz
Posted: Thu Jul 27, 2017 12:49 pm
by pgk
Sure is!!
Posted: Thu Jul 27, 2017 5:38 pm
Practicing for a brazing cert, copper to copper using Harris Stay-Silv white flux and Safety-Silv 45 brazing alloy
Have to do 3/8" and 2" tubing
- for nitrogen purge
- 20170727_130134a.jpg (41.45 KiB) Viewed 4429 times
- 3/8 tubing
- 20170727_130619a.jpg (65.85 KiB) Viewed 4429 times
- 20170727_134911a.jpg (65.08 KiB) Viewed 4429 times
Posted: Thu Jul 27, 2017 6:53 pm
by sedanman
I got my welding cart done. I work for a bus company and need the security this setup gives me.
Posted: Thu Jul 27, 2017 6:57 pm
by sedanman
Closed
by sedanman
Could a moderator please rotate my pictures?
Posted: Thu Jul 27, 2017 7:28 pm
by Coldman
Open your pic in "Paint", save it in correct orientation and reload. Default windows viewers often load sideways, didn't used to but hey MS has to justify an upgrade somehow!
Posted: Thu Jul 27, 2017 7:32 pm
by sedanman
I only have a smartphone.
Posted: Thu Jul 27, 2017 7:54 pm
by Coldman
Sorry, can't help you there. I only have rotten fruit.
Sent using Tapatalk
Posted: Sat Jul 29, 2017 6:45 pm
by GreinTime
A little weld detail from those Honda manifolds, and my newest toy (RogueFab M600) to play with!
Posted: Sun Jul 30, 2017 3:36 pm
by nelson
What is that? A hand powered hydraulic coal scorp?
Posted: Sun Jul 30, 2017 4:32 pm
by GreinTime
nelson wrote:What is that? A hand powered hydraulic coal scorp?
It's an air/Hydraulic tubing bender!
