Page 106 of 131
Posted: Thu Jun 08, 2017 7:33 am
by Warrenh
![Image](https://uploads.tapatalk-cdn.com/20170608/a204a15ff577f7c9442e0ec0a5cde9d7.jpg)
![Image](https://uploads.tapatalk-cdn.com/20170608/ef6c80338fbde68cc76e3e33e20b42ae.jpg)
Leaning post for a poling platform on a flats boat.
Posted: Sat Jun 10, 2017 8:22 am
![IMG_2210.JPG](./download/file.php?id=12851&sid=fc9a153c5289986efb582107dd6e2a82)
- IMG_2210.JPG (36.26 KiB) Viewed 2787 times
New gas service at one of the local schools. Gas provider set the new meter and I ran new pipe into the building. Only had a 4 hour window for actual shut down.
Posted: Sat Jun 10, 2017 10:00 am
by Coldman
4hrs that's crazy man. You wouldn't have had time to scratch !
Sent using Tapatalk
Posted: Sat Jun 10, 2017 12:56 pm
Fortunately I was able to do most of the work ahead of time. the only thing left on shutdown day what's to bolt up the last 4 inch flange and do the two welds on the tee.
Posted: Tue Jun 13, 2017 8:15 pm
by Rick_H
Made a nice adjustable engine support while I swap the junk auto out of my TDI Jetta. A few pics of some oher stuff I'm building...
Posted: Wed Jun 14, 2017 12:59 am
by 5th Street Fab
Otto Nobedder wrote:5th Street Fab wrote:... I finally got a bottle of helium at home...
Sweet!
I have the incredibly rare blessing of completely unlimited access to helium. One of our clients provides whatever we ask for because I use it in leak detection.
Steve
Lucky man! I got to finally use some at work today. I'm hooked. Now if only they would get it for everyday use!
Posted: Fri Jun 16, 2017 1:04 pm
by crimas
Today i made two simple cordless drill holders and weld four adjustable legs for an assembly table made for line assembly of kitchen ovens. All make with 304 stainless steel scarp from ovens productions, the square tube for the legs are just 1mm thickness tig welded
![Cool 8-)](./images/smilies/icon_cool.gif)
Posted: Sun Jun 18, 2017 11:46 am
by 5th Street Fab
Posted: Sun Jun 18, 2017 8:24 pm
by BigD
This was terrifying but so exciting! I posted earlier the beginnings of this, now it's all done, just need to add some sensors and pressure references, maybe a brace to the block. Last week I finally got off my ass and bought the plenum metal, and went to my friend's shop with a big press with my angle and rod to bend it. It worked well with the experiment with the coolant tank so I was cautiously optimistic. But even with 3003, it is just too much length with a single pressure point. The 1.5" solid aluminum bar bent before making much of an impression on the sheet (3/16" thick). I called several audibles, one was a steel jack handle, that crushed. Finally we found a 1.5" solid STEEL bar, I cut it to length and that finally worked. It almost seemed like it wasn't going to, it was bending a lot but wasn't yielding and when it bottomed out in the angle, it straightened out the bend. PSI is a bitch, I'm from an RC airplane model background and I should have an appreciation for load distribution but it's still hard to picture intuitively.
Alls' well that ends well, I'm SUPER stoked with the end result, I was cautiously optimistic that my skill level was now where it needs to be but I always tend to attempt things when they're at least a notch outside of my comfort zone and sometimes ability but that's what makes it fun...
![intake manifold 1.JPG](./download/file.php?id=12931&sid=fc9a153c5289986efb582107dd6e2a82)
- intake manifold 1.JPG (67.72 KiB) Viewed 3047 times
![intake manifold 2.JPG](./download/file.php?id=12932&sid=fc9a153c5289986efb582107dd6e2a82)
- intake manifold 2.JPG (91.87 KiB) Viewed 3047 times
![intake manifold 3.JPG](./download/file.php?id=12933&sid=fc9a153c5289986efb582107dd6e2a82)
- intake manifold 3.JPG (66.36 KiB) Viewed 3047 times
![intake manifold 4.JPG](./download/file.php?id=12934&sid=fc9a153c5289986efb582107dd6e2a82)
- intake manifold 4.JPG (95.62 KiB) Viewed 3047 times
Posted: Sun Jun 18, 2017 8:40 pm
by Farmwelding
That looks fancy and like you did a heck a job welding that all out.
Posted: Sun Jun 18, 2017 9:51 pm
D that looks nice and clean!
Posted: Mon Jun 19, 2017 4:46 pm
by BigD
Thanks a lot guys!
Posted: Mon Jun 19, 2017 8:35 pm
by Gene.243
I put a lot of effort into today's welding.
Posted: Tue Jun 20, 2017 8:40 pm
by Rick_H
My filler tooling cabinet is complete finally and out on the floor.
Posted: Tue Jun 20, 2017 9:05 pm
by Coldman
Beautiful work as usual
Sent using Tapatalk
Posted: Tue Jun 20, 2017 10:16 pm
How many times have you had to patch the flighting on those augers? Nice work.
Posted: Tue Jun 20, 2017 10:23 pm
by crimas
some practice with an aluminum box
![Image](https://uploads.tapatalk-cdn.com/20170621/03646abe0cedfce9c2f987b0234b4939.jpg)
Posted: Wed Jun 21, 2017 6:53 pm
crimas wrote:some practice with an aluminum box
Nice looking welds
Posted: Wed Jun 21, 2017 7:38 pm
by jernigan78
Finished a new welding positioner project that I have been working with a local machine shop on. Ran some tests, works well. Played around last night running some autogenous welds with the torch strapped to my steady-rest. These were done at 2pps. Different amp settings for the different spots. I guess its a pen holder for my desk at work. haha.
Posted: Thu Jun 22, 2017 7:07 am
jernigan78 wrote:Finished a new welding positioner project that I have been working with a local machine shop on. Ran some tests, works well. Played around last night running some autogenous welds with the torch strapped to my steady-rest. These were done at 2pps. Different amp settings for the different spots. I guess its a pen holder for my desk at work. haha.
Looks great, would like to know more about your rotator build
Posted: Thu Jun 22, 2017 10:05 am
by pgk
Awesome looking beads..
Posted: Fri Jun 23, 2017 10:43 am
by GreinTime
Double post.
Posted: Fri Jun 23, 2017 10:44 am
by GreinTime
Some aluminum on some intercoolers, and some titanium from Ticon in one of their sample kits!
![Image](https://uploads.tapatalk-cdn.com/20170623/205a2786e66e618a77fe9bd28c59d280.jpg)
![Image](https://uploads.tapatalk-cdn.com/20170623/d38db66f95aefa40ac948be3737a4509.jpg)
Posted: Fri Jun 23, 2017 11:14 am
The titanium came out nice! Sucks having to wait for it to cool down though.
Posted: Fri Jun 23, 2017 3:04 pm
by GreinTime
Oscar wrote:The titanium came out nice! Sucks having to wait for it to cool down though.
The whole thing was done consecutively alternating joint to joint. I think it's 4" sections maybe?
