Re: Help me with my Aluminum issue
Posted: Sat Apr 02, 2016 9:28 am
Or set your torch in some type of fixture and watch the display.Poland308 wrote:Video record the display then weld as normal
The Forum
https://forum.weldingtipsandtricks.com/
https://forum.weldingtipsandtricks.com/viewtopic.php?f=5&t=9306
Sounds good now, gotta like the easy fixDcstang67 wrote:Here is the video of me welding some of the same tubing. Believe it or not fixing that slight argon leak solved the problem completely. Thank you everyone for all of your help.
https://youtu.be/8RqoCQ_5Qco
Sent from my SAMSUNG-SM-G900A using Tapatalk
Now that your up and running why not consider doing a review of the machine in the "Products Review" forum, seems it's popular and others may benefit from your experience with this unit.Dcstang67 wrote:She's welding pretty now!
exnailpounder wrote:I thought of something....My machine has a setting for tungsten diameter, I am sure yours does too, did you check that and change it? Also, you referred to arc length as compared to 1/8" metal. That is not arc length, that is stickout and you should have way more than that otherwisw you can't see your puddle. Arc length is when you are welding, how close your electrode is to the puddle. You want to stay within 1/8" or so. Any farther away and your arc will get unstable and wander, among other things. Also, your machine doesn't have enough ass to be doing anything with 1/2" material, especially aluminum. Rule of thumb is 1 amp for every thousand of an inch..example...125 amps for .125 (1/8"). You may have to play with that but that will get you in the ballpark. I would go watch some of Jodys videos. They are great and he doesn't leave anything out.
