Take a band saw and cut a notch down the side to expose the edge of the wheel so you can cut off blobs of crap. The crazy fine taper on the 1/16" was pretty easy to give up for a cut off slot.hey_allen wrote:One of the comments made on Thingverse where the first post links to mentioned that issue, and suggested modification of the part to add a slot to the side, allowing the cutting of the tungsten when blobbed.sru_tx wrote: The downside is when I really mess up, dip the tungsten and get a large blob on the end. It won't fit into the fixture's openings so another grinder is needed or the fixture needs to be modified with an access port to clean up really messed up tungstens.
Entity, I love a good hijacking
-Sandow
