Steve,
I have a tip (from experience; I use it daily at work) for conserving that expensive helium.
Lose the 1/4" compressed air line. A helium atom is the smallest thing in nature outside of a laboratory or the core of a star, smaller than a hydrogen molecule, and will leak out of damn near anything at an alarming rate.
Use DOT rated 1/4" air brake tubing (nylon) and appropriate compression fittings with inserts. Ask a local tractor/trailer shop or supplier. You will lose far less helium through "diffusion". Use a soap-and-water solution (or "SNOOP"(tm) if you can get it.) to trace all your lines and eliminate any leaks. And, obviously, set the helium percentage to the minimum to satisfy your needs.
Nice ride, BTW. Did you get the heated seats with that? They are awesome in northern winters!
Steve
Otto, I went through the whole hose ordeal. I ended up with just what you recommend. The 1/4 air compressor hose not only leaks it also contaminates and pretty much sux's in general. I pump 120 psi to the mixer to make it work properly. When I'm done for the day, I back off the pressure gauges at the tank and then turn the tanks off. They hold on the high side just fine but I usualy forget to turn the flowmeter and the torch valve off so I lose what's in the hose. I've been fairly impressed by the lack of gas consumption. It's actually pretty close to 80/20 on the tanks. I'm down a little over 1/3 (250 tanks) on the argon after about 200' of weld on 1/4" at 18cfh.
The truck is the Lariat package aka XLT. It has all the bells and whistles (seat heaters, etc.) but not the full Kings Ranch package. Ford is pretty good about putting everything you need in the truck to add whatever you want later. Things like the alarm system, keyless remote and remote start were all installed I just needed to pay for the key fob and have it activated with a simple reprogramming of the ECU. Chevy/GMC seems to leave the stuff out completely and make you pay for the full option if you want it installed later.
Steve,
Sorry for sounding abrupt, but I was hoping you kept the Lincoln (then we could share techniques) and added an inverter to your collection. It is always cool to have a vast selection of cool tools to play with. I agree with you about life timing and spending money, I am around the same age and often thinking 'should I..... or shouldn't I', that lasts for about 20 seconds then I make a bee line for the computer to place my orders.
I know one thing, if it's fun then it always cost more than you think, here is my example. Purchased the Lincoln Precision TIG 225 for 2060.00, no tax or shipping from Indiana Oxygen Company. As you know, the welder comes with a great set of accessories, and you think that is all you will need to spend. Then you realize, and start thinking seriously about all the other stuff you need to begin this new welding adventure the right way. So, my good deal at 2060.00 became 3200.00 instantly. Then, while I was learning to sharpen tungsten's using my Belt Grinder, I discovered that the expensive belts I purchased (Zirconia or Borazon from Norton), one lasted about 4 hours, but got the job done. As I read more, and became more aware of the details of this highly technical welding type I realized I would need to grind with diamond get a better more accurate taper. So I purchased a Sharpie from Arc-Zone (another 450 with extra grinding wheels). So, I am around 3700.00 now, and after spending all this money I can see one very important thing, my AL weld beads are getting better and better.
I was sorry to here about your medical event , I hope you are feeling better. And you are right when a traumatic event happens in your life you do start thinking about doing things you want to do in the time you have. As the Kansas song says " and all your money not another minute buys".
Now stop reading this forum and go out and play with the new metal melter. Try welding a razor blade to a coke can to a banana.
Wob
Wob
WOB
Lincoln,Precision TIG225
Miller,Millermatic 251
Miller,Spoolmatic 30A
Miller,Millermatic 130XP
Miller,Spectrum 625
Miller,Thunderbolt 225AC
KMG,Belt Grinder/2x72
Ingersoll Rand,Compressor/5HP
Miller,Spectrum 625
Hey, Steve Schefer,
I decided to use your full name, because there are several Steves here, and I'm also a "Steve S."
Good for you! It's hard to make any system helium-tight. If your high-side gauge is holding overnight, your system has very low losses for helium.
Steve S.
Steve S.
LOL, I just remembered how mad I was when the brand new Smith $250.00 high pressure guage set was leaking on the Helium side. After messing with it for a while I got it to seal pretty well and later realized I was darn lucky to get it to seal at all.Otto Nobedder wrote:Hey, Steve Schefer,
Steve S.
I'm sure you know this trick but for others who don't -- Always open your tank valves all the way to the stop. The stop is a seal also and anything in between is not sealed and will leak at the valve stem. You can lose a lot of gas through the course of a day and not be able to see or hear the leak.
Steve,
Opening the gas valve all the way is something I learned in high school, and was reminded over the years by my local welding supply (Arc-Gas) when I visit them for more gas. I did not remember about the seal that functions when the tank valve is opened all the way, thanks for resetting my memory regarding that fact. By the way that is nice truck, should I post a picture of my 2010 Toyota FJ Cruiser TTS ?
Wob
Wob
- 2010_FJ_Cruiser_TTS_Cp.jpg (32.52 KiB) Viewed 1948 times
WOB
Miller,Spectrum 625
Miller,Spectrum 625
Quite true. Any high-pressure bottle has a built-in positive seal that works when the valve is fully opened.
Acetylene is the exception. It is a low pressure gas, dissolved in acetone, and the valve should only be open 1/4 to 1/2 turn. This allows you to stop the flow of fuel with one wrist movement in an emergency.
IMPORTANT!
FOR THOSE WHO DON'T KNOW:
If you ever have to lay your acetylene bottle on it's side, let it stand upright several hours before you crack that valve! You could contaminate your regulator with acetone, destroy seals in it, and over-pressure your lines. Acetylene gas above 15 PSI can spontaneously break down and combust in the lines without oxygen present.
Steve
IMPORTANT!
Steve
Good post. I was taught that 40 years ago and never had to learn it the hard way.IMPORTANT!
Thanks
Sarge
- Sarge
Great safety tip!!! I am so glad that safety is a prominent concern on this site. You guys are great!
Be Innovative.
Goal is perfection, but excellence is Acceptable.
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
We would all probably go into shock if a survey was done and an actual number produced of the percentage of people out there working with high pressure and flammable gasses that are totally clueless to things such as that. Or to the proper procedure of how to start-up and then shut-down cutting torches.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
footboarder
- footboarder
I would get a cheap non-contact infrared thermometer and check all the connections after a breaker opens. TIG to outlet, extension cord 'if used', breakers inside the panel, 50 amp feed connections inside the machine, wires. For some reason #8 does not sound right to pull 50 amps. Off hand i believe 50 amps is into those 'ought' sizes.
Just look at any rig truck going down the road. How many people know it's illegal to drive with the gauges on? The bottles are supposed to be CAPPED for transport. I don't know of anyone getting a ticket for this, so a lot of cops don't know, either.jpence38 wrote:We would all probably go into shock if a survey was done and an actual number produced of the percentage of people out there working with high pressure and flammable gasses that are totally clueless to things such as that. Or to the proper procedure of how to start-up and then shut-down cutting torches.
kermdawg
- kermdawg
Man, can I tell you stories about transportin acetylene. I didnt know no better ( I was 19 at the time) but now that I do, man I am SO lucky I didnt blow myself or someone else up. And then you see guys on the job with their B tanks layin down on their carts or lifts, prop em up, hook em up and fire away, they have no idea how dangerous that is.
Funny part is, our safety meetings every week-once a month our safety meeting is on CGC's(compressed gas cylinders). Everytime my apprentice would crank open the acetylene bottle and only open the oxy bottle half way I wanted to whack him upside the head with my ballpeen hammer.
Oh, and those bottles are supposed to be capped whenever they are not in use for more than 1 hour. Osha :p No leavin your cuttin torch setup hooked up all day :p
Oxy-acetylene bottles may be left "hooked up" up to 24 hours if on a certified "firewall" cart.
Steve
Otto Nobedder,
When you were talking about the #8 wire being marginal for 50 Amps, it depends on the length of the wire.
The Lincoln Precision TIG 225 is provided with a #6 cord connected with plug for a 50A 240 VAC circuit.
When I was setting up power for my shop I had to run 220 VAC 180 feet to my welding shop. For this run I used #4.
From the panel in the shop I am running #8, stranded to increase the circular mill area of the cable (using SO Cord).
Stranded wire has the capacity to carry more current than a single solid copper wire.
The #8 length is approximately 25 feet.
The last 6 feet is the Lincoln's #6 power cord.
Wob
Wob
WOB
Miller,Spectrum 625
Miller,Spectrum 625
kermdawg
- kermdawg
@otto-
They told us 1 hour when I was working at the airport, but that might our state osha codes.
I ran my outlet about 100 feet to my garage (panel's on the other side of the house) with 8/2 solid wire cable. The electrician I had install it said it was about the minimum you could go for that length of run. Basically anything more than 100 feet he said I should run #6. But, im not welding at 200 amps on some aluminum either :p
The 24 hr thing is (or at least was) a fed. OSHA thing. Nothing keeps a particular job site from establishing stricter rules for safety, and I can't think of a more "safety oriented" place than an airport.
As for the electrical issues, I may have been confused for one of the many other "Steve"s on here. I rarely comment on electrical issues beyond my range of certainty. I have experience in three-phase and split-phase wiring in many settings, but it's not my trade, and I must consult the tables for run v. current EVERY time I wire something.
If I actually commented on wire sizes, I was speaking out-of-turn, and probably under the influence of beer.
Steve
Steve
Beer is good, err was good, I gave it up 6 years ago. I don't miss it but I sure can't figure out where all them pretty girls I used to date went. All I ever see now are ugly ones that I would never date. Funny, they seem to have the same names as the pretty ones. Nah, just coincidence I'm sure.
Steve,
They're all pretty when you've been happily married for twenty years. Flirting is not a crime. (Unless your wife catches you. But after this long, she understands.
If you need to "drink 'till she's pretty", you have more than one problem!
Steve
Steve
