dirtmidget33
- dirtmidget33
@Nitram88 there is no delay issues with pedal. The Thermal Arc 186 is a great welder. The one thing I do not like about it is the torch. The 26 is huge and cable is very stiff. Suggest buying a CK torch with the flex line. I did also add a quick disconnect to gas line since I change torches a lot, going from 9 to 17. You could avoid that also by just getting a CK 26 with flex line. Lot easier to use than that stock 26, if you go that route I suggest the trimline 26.
Thanks for all the replies guys. Glad to see this forum is active. Sorry i have responded. Work has been kicking my ass. So next month ill have roughly 2000 to spend on a welder. Are any of the 3 in 1 welders even worth it? I can stick and mig and dont have a welder at home so the thought ran throug my mind. Also can i plug a welder into the dryer socket or do i need to have new one installed?
Your dryer outlet is likely 50A/220VAC, so, yes.b1105 wrote:... Also can i plug a welder into the dryer socket or do i need to have new one installed?
Keep your cord either heavy or short. Your outlet is likely wired 10/3 w/ ground, and if it's within 15' of the box, you can almost ignore losses.
Bill Beauregard
- Bill Beauregard
A proper welder circuit will either be sized for the biggest welder it will see. This might mean lighter than 50 amps if you are able to benefit from duty cycle de rating, or much heavier if the transformer is far away. The breaker size will likely be larger. If your dryer is properly wired, it should be on a four wire circuit. Welders need three. Most importantly, you probably shouldn't weld in the laundry room. If using a cord means passing through a doorway, we both know the cord is going to get shut in a door.Otto Nobedder wrote:Your dryer outlet is likely 50A/220VAC, so, yes.b1105 wrote:... Also can i plug a welder into the dryer socket or do i need to have new one installed?
Don't get electrocuted, or burn your house down, put in an outlet. It isn't that big a thing to do.
I've seen a thousand 30 amp dryer circuits, never a 50.
