Re: Tube welding- looking to get to the next level?
Posted: Wed Nov 26, 2014 1:58 pm
good clean fit ups makes life easier
The Forum
https://forum.weldingtipsandtricks.com/
https://forum.weldingtipsandtricks.com/viewtopic.php?f=5&t=6339
Either one [rod] you pick, will require you to finesse your technique in one way or another. With the 0.045" filler rod, you would need to develop years worth of muscle memory over-night in order to feed the rod fast enough [and more importantly accurately enough] without hiccup'ing as you're moving down the weld joint. With 1/16" filler rod, you have to both feed the filler [though not as much], and always be cognizant of the "stickiness" of it should the puddle not be the correct size due to heat input, which means you have to have a kung-fu death-grip on it, not always possible with those soft-skin TIG welding gloves.jcw wrote:zank wrote:I tried the 1/16" rod previously and it would chill the puddle too much and the rod would occasionally stick. But now with more heat, I'll try it again. That joint had a rather bad fit up as well.
Ron,steeldr. wrote:Washing over a weld to smooth its surface without adding filler wire is not a recommended process, it could weaken the joint because of the heat input. metallurgical changes, and grain growth. You could add additional weld then contour to a smooth surface. This creates a lot of additional work, but the end results is the target.
My comments are not to disagree with anyone, but to encourage a better end product.
Ron
Oscar wrote:Either one [rod] you pick, will require you to finesse your technique in one way or another. With the 0.045" filler rod, you would need to develop years worth of muscle memory over-night in order to feed the rod fast enough [and more importantly accurately enough] without hiccup'ing as you're moving down the weld joint. With 1/16" filler rod, you have to both feed the filler [though not as much], and always be cognizant of the "stickiness" of it should the puddle not be the correct size due to heat input, which means you have to have a kung-fu death-grip on it, not always possible with those soft-skin TIG welding gloves.jcw wrote:zank wrote:I tried the 1/16" rod previously and it would chill the puddle too much and the rod would occasionally stick. But now with more heat, I'll try it again. That joint had a rather bad fit up as well.
You'll get it eventually, just keep practicing [something I need to do more often---stupid work schedule]. You[we]'ll get it.
