soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Sparks, NV
AdVirMachina wrote:Ok, strapworks.com has 2" for 60¢ a foot. This is measured across the flat, so if you cut it and laid it out, it would be 6 1/4" or so.
Irving, TX. Epicenter of the Metroplex!
2" width laid flat is 4" total length or 1.27" cross section as a circle diameter
Sent from mobile. Not responsible for Typos
soutthpaw
    Sparks, NV
AdVirMachina
    Thu Feb 27, 2014 10:42 pm
Yup. Stupid pi. I was calculating it as a 2" round.
    Wed Nov 19, 2014 8:20 pm
    S.W. Pennsylvania
O.k. so I made a purchase from wirecare for a cable cover. I am happy with how it fits. It seems like it will last awhile. Only time will tell.
Brian
Brian
Miller Thunderbolt 225 AC/DC
Everlast 255EXT with W300 cooler
Hobo Freight 170 MIG Welder
    S.W. Pennsylvania
Fixing double post
Brian
Brian
    S.W. Pennsylvania
Don't know why that first picture is upside down?
I did buy some heat shrink mesh to terminate the ends also. But I bought to small a size and it will not fit over the torch and switch like the webbing did. I just used electrical tape till I place another order.
Brian
Brian
melsdad wrote:Don't know why that first picture is upside down?
Brian
Brian
The cover certainly looks nice, hard to tell from the pics but it seems to be tight around the cables. My first thought was if the power cable is overheated then it may be more likely to damage one of the other cables.
Did you install this from the torch end? Slip it over like a sock?
Also please provide the part number for what you bought, the photo of the label doesn't show that.
Thanks
    S.W. Pennsylvania
It is a nice fit. not tight, not sloppy either. The material should be able to breath since it is an expandable mesh. I would imagine cables inside a leather cover would hold way more heat than this material.
Yes, I slide it over the torch end...even went right over the torch switch.
Here is the part number and description:
SDN0.75BK SuperDuty 3/4" Nylon 6/6 Black, 25 ft cuts $30.00
And link:
https://www.wirecare.com/search.asp?term=SDN0.75BK
Brian
melsdad wrote:It is a nice fit. not tight, not sloppy either. The material should be able to breath since it is an expandable mesh. I would imagine cables inside a leather cover would hold way more heat than this material.
And link:
Thanks and good point about the leather cover.
I have been looking on their website, a lot of options to choose from, the carbon fiber sleeve would be cool. Part # CAL0.50BK
The torch my thermal arc 186 came with has leather on the last 3 ft or so it's nice and flexable.
