Those HTP parts you bought are kinda high tech for some more delicate work, not really for general pipe and plate practice.
I use HTP gas lens, and they hold up good.
Here's the ones I buy.http://www.ebay.com/itm/200327823689?ss ... 1423.l2649
But for your application, regular collets and stuff work good because the bevels and such help shielding.
2cents
~John
- mike boyer
A Honeymoon Dick??? LMAO...Len...I gota steal that one if you don't mind..Mama was sittin hear readin ..& she's crackn up too...DAM!! Ok Rereading your replies(len,nick & John) Got me thinkin....A couple times i had to dis & reassemble..Tungsten was loose( slid in & out)...I feel a BONEHEAD rookie moment about to rear it's ugly head....I'll be right back. ..let me see if I can.."re-create the crime scene....... (10 mins later) Ok....I think I see what I did......I guess when you put the wrong collets in..BAD THINGS HAPPEN...OMG!!!!!...Just went thru the assembly process just like before, only THIS TIME I was paying attention....Put the wrong collets in the new HTP stuff...Rookies..They just awta be shot sometimes....LMAO...
Good observation, I think that will help keep you from eating collets.
Still doesn't explain why the torch got really hot....
File this experience away, Always check and see if your parts are all the same size.
But you said you were using 1/8 tungsten, How did you have the wrong size?
~John
~John
BTW,
If newbs were shot for their first mistakes, none of us would be here.
And we all make mistakes, we just call it experience.
True story,
~John
True story,
~John
AMEN!!!AKweldshop wrote:BTW,
True story,
~John
- mike boyer
Here's what I did...Used wrong collet in HTP body....Live an learn....I think the pyrex needs a longer stick out..I was out an 1/8 or so..Read & saw( from AK's link) they come out 6-8 diameters....A LLLOONG way... Now I'll go stand in the corner...LOL
- Here's everlast parts...
- 005.JPG (78.72 KiB) Viewed 785 times
- Here's where it went wrong!!!
- 004.JPG (69.83 KiB) Viewed 785 times
- Here's HTP Stuff
- 003.JPG (78.32 KiB) Viewed 785 times
So now that you solved one of the problems....
Is the torch functioning/welding???
~John
~John
Arizona SA200
- Arizona SA200
- Braehill
Mike,
I see by the picture of the HTP stuff with the Pyrex cup that you already have at least one wedge collet. I believe CK makes them in most sizes for most different types of pilots i.e. stubby or 4 series, 2 series, 3 series etc. and they can't twist like the slotted ones.
- mike boyer
Having the wrong collets installed..I had already smoked both ends of the 3/32...The next day my little sharpie diamond wheel showed up....SOOO..I hooked it up to my dremel..and sharpened up everything again..Got a tungsten grinder for $8.00..lol (those 300-400 $ ones are nice,but this works for $8.00)...AZ...LEN..had me ROLLIN..I was LMAO.The Boom arm sent me over the edge...Hey LEN..The collets that came with the HTP stuff are pretty beefy...I stuck the collet that came with the Everlast torch in by mistake.....Live & learn I guess....
I posted this elsewhere here before but I use one of these for tungsten sharpening.
http://m.harborfreight.com/120-volt-cir ... 96687.html
It's a harbor freight circular saw blade sharpener, I removed the guards, and replacement diamond wheels for them are like three bux. With the coupon and sale it was $30 for a diamond wheel tungsten grinder.
- mike boyer
