Sorry, I blew right past this post and didn't even see it earlier. No, that is nowhere near 1/8 inch. As I said in the post above, it's 0.058 material. I used either 16th in filler or I also tried .035 mig wire. I was welding a potato chip just trying to show the example for the op.TraditionalToolworks wrote:If that is 1/8" you might try leaving the amps the same and using a large size filler. Inside corner takes some heat, but you need to use a fair amount of filler so it's doesn't keyhole on 'ya. If it is 1/8" material you should have the pedal floored on the inside corner. (do as I say, not as I do... )
Are you using 1/16" filler?
In the beginning it doesn't look too bad, but possibly not enough filler as you didn't get the stacked dime effect.
- TraditionalToolworks
If light pedal works for you, stick with it.BugHunter wrote:Sorry, I blew right past this post and didn't even see it earlier. No, that is nowhere near 1/8 inch. As I said in the post above, it's 0.058 material. I used either 16th in filler or I also tried .035 mig wire. I was welding a potato chip just trying to show the example for the op.
Was confused, sorry, but using 125 amps with a light pedal for 1/16" material is probably something I wouldn't personally do. You may be more experienced that me, I find it best for me to use the max amps and a heavy pedal, I can always back it off. But using a light pedal shortens the travel of the pedal greatly which there are no real settings for, it's arbitrary for your foot.
Anyway, never mind me...
Collector of old Iron!
Alan
Alan
On steel I would agree with you, but on aluminum I like having lots of extra power available in case I want a bunch of momentary heat. Even on something like this 17 gauge. Maybe even especially on the lighter stuff. I've never had good luck sitting still and dwelling on a part while I wait for it to warm up. I can always lift my foot some more. I wish I had a video of the machine so I could tell what it was running. I bet it was higher than you might think.
