Page 80 of 131
Posted: Sun Jul 31, 2016 12:41 am
by Rick_H
Little sifter screen repair for a product feeder. I ended up cutting the old piece out and welding in a new section. Not the coolest thing I do but I do a lot of these based on vibration damage....the wire mesh is .090". They have to be welded sanitary with no crevices.
Posted: Sun Jul 31, 2016 2:39 pm
by Alumike
[/attachment]
- final weld OLds.jpg (37.4 KiB) Viewed 1942 times
A cracked Olds intake manifold that I repaired.
Posted: Sun Jul 31, 2016 10:42 pm
by Rick_H
Made a cart to hold all the parts to a labeler at work to prevent damage. I made one a year ago and damage is own 98% just have to cap somethings off and do the finish work.
Posted: Mon Aug 01, 2016 12:09 am
by subwayrocket
Posted: Mon Aug 01, 2016 9:06 am
by Rick_H
That should work nice! A lot easier to grab that is for sure ...
Is the Mill up and running?
Posted: Mon Aug 01, 2016 6:44 pm
by subwayrocket
Rick_H wrote:That should work nice! A lot easier to grab that is for sure ...
Thanks, yes it's all set up. Cosmoline all cleaned off, oiled, re-greased, trammed. Getting to know the machine. Matt at Quality Machine Tool in Pittsburgh has been a big help. I started doing a few things with it. I milled flats on the shank of all my import Shars boring bars. Faced all my big Alum chill blocks . Hoping to get a machinist buddy down here to get me going better ! The speed wheel works pretty good. It's weight gives it some inertia like a fly wheel...so opening/closing goes faster. Threw some paint on it...and since it's the only American made thing on the whole mill I threw the little flag on it ...lol . Here it is on the mill .
- SpeedHandle-onMill-Painted.jpg (69.33 KiB) Viewed 2197 times
- Buddy.jpg (84.23 KiB) Viewed 2197 times
Posted: Wed Aug 03, 2016 11:59 am
by maker of things
Finally good use for Harbor Freight indicator base
- IMG_20160723_110923565.jpg (92.18 KiB) Viewed 2182 times
Posted: Wed Aug 03, 2016 12:06 pm
by maker of things
Ace, nice setup. Once you have used a speed handle on a mill vise, it's pretty had to imaging not having one huh? I share your opinion of Matt. Got my 1440 lathe from him and am very happy with his machine and service.
Posted: Wed Aug 03, 2016 1:33 pm
by subwayrocket
maker of things wrote:Ace, nice setup. Once you have used a speed handle on a mill vise, it's pretty had to imaging not having one huh? I share your opinion of Matt. Got my 1440 lathe from him and am very happy with his machine and service.
Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$
Posted: Wed Aug 03, 2016 2:27 pm
by maker of things
subwayrocket wrote:Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$
ain't that the truth! My rule on that:
Give a person a tool, they can finish a project. Give that same person a reasonably equipped shop and they will forever be one tool/machine away from starting yet another project.
Posted: Wed Aug 03, 2016 5:08 pm
by exnailpounder
maker of things wrote:subwayrocket wrote:Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$
I always wished my tool was bigger...sorry...you asked for it
Posted: Wed Aug 03, 2016 8:44 pm
maker of things wrote:Finally good use for Harbor Freight indicator base
Good one!
Posted: Fri Aug 05, 2016 7:13 am
by maker of things
Some hanger-uppers for torches and work cables on the end of my weld bench.
- weld shop 010.JPG (48.1 KiB) Viewed 2069 times
Posted: Sat Aug 06, 2016 6:44 am
by motox
maker,
nice touch!
Posted: Wed Aug 10, 2016 1:16 am
by Rick_H
Making some stuff...
Steel tank legs, stainless frame I made 309L wire
Posted: Wed Aug 10, 2016 1:30 pm
by entity-unknown
Is that "Passover" tank for that special holiday feeding time?
Posted: Wed Aug 10, 2016 2:55 pm
by Rick_H
entity-unknown wrote:Is that "Passover" tank for that special holiday feeding time?
Was an old vessel we used for some special Passover items we make at work.
Posted: Wed Aug 10, 2016 4:31 pm
by maker of things
- IMG_20160810_151256471_HDR.jpg (56 KiB) Viewed 2209 times
My hasty "make sure the new machine can weld at 210 amps on AC and 5 on DC" tests. Did a poor job cleaning the aluminum which was also junk from coexisting with steel scrap for a few months. For almost an inch there (all together) it doesnt look too bad.
Posted: Fri Aug 12, 2016 10:01 pm
by zank
One from yesterday.
0811161644_HDR by
Mike Zanconato, on Flickr
Posted: Sat Aug 13, 2016 7:25 am
by Fe3c
I bought a wrecked car a few months ago with the intentions to turn it into a race car. Well, my daily driver caught on fire so I had to whip the project into shape in short order.
What I started with.
In progress.
Done other than tweaking the headlight bucket on the driver's side a little bit.
Posted: Sat Aug 13, 2016 4:58 pm
by maker of things
- IMG_20160813_090953806_HDR.jpg (107.85 KiB) Viewed 2093 times
First real try at the razorblade challenge I heard about on the welding tips n tricks podcast. 15 amps .04 lanthanted 20cfh using .035 mig wire for filler. That stinkin puddle is really hard to see. I turned my hood down to 6 shade and once I initiated the arc I realised I had set up way too far away.
Posted: Sun Aug 14, 2016 11:00 am
by Rick_H
Got my fittings welded in, tank and stand complete now to add some process piping and a filter.
Posted: Sun Aug 14, 2016 11:02 am
by Rick_H
Cementite nice project!
Posted: Sun Aug 14, 2016 1:13 pm
Rick_H wrote:Got my fittings welded in, tank and stand complete now to add some process piping and a filter.
Rick, nice job on the couplings!
Posted: Mon Aug 15, 2016 11:05 am
by Rick_H
Thanks Rich...
Stand mocked up in place, need to wait till the tank and cleaned then Ill paint the stand with some Steel-It and they will sanitize and put into production.
