Looks good (for real) and amazing how you were able to weld the Aluminum to the PVC.Rick_H wrote:Made a new platform section for a piece of equipment, 304 frame, alum diamond plate.
Jim S.
Miller 211 Autoset
Everlast 255EXT
Everlast Water Cooler (2)
Everlast PowerPlasma 80S
Longevity 250MP
Lincoln 350MP Aluminum
Hypertherm 30Air
Everlast 350EXT
Miller 211 Autoset
Everlast 255EXT
Longevity 250MP
Hypertherm 30Air
Everlast 350EXT
It's a special torch and filler designed, I can sell you one of you'd like..shipj0 wrote:Looks good (for real) and amazing how you were able to weld the Aluminum to the PVC.Rick_H wrote:Made a new platform section for a piece of equipment, 304 frame, alum diamond plate.
In all seriousness I used those as spacers so it would hold dimension if it pulled in, I have to weld that end to an existing structure. Cheap and effective.
[/quote]It's a special torch and filler designed, I can sell you one of you'd like..
I would imagine a torch like that would be quite rare and expensive. I'll have to keep the PVC trick in mind, good idea.
Jim S.
Miller 211 Autoset
Everlast 255EXT
Longevity 250MP
Hypertherm 30Air
Everlast 350EXT
Miller 211 Autoset
Everlast 255EXT
Longevity 250MP
Hypertherm 30Air
Everlast 350EXT
I would imagine a torch like that would be quite rare and expensive. I'll have to keep the PVC trick in mind, good idea.[/quote]shipj0 wrote:It's a special torch and filler designed, I can sell you one of you'd like..
Fill rod home depot
Torch Harbour Freight
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
dirtmidget33
- dirtmidget33
This isn't a welded today but welded before Christmas. My wife is impossible to shop far. So instead of buying her anything I made her something that she has been looking for and cant find. For years she was looking for a stocking holder that holds more than one stocking. The stuff in stores is pretty lacking and not what she is looking for. So I designed her a holder for her Christmas present. Unfortunately I didn't get production pics of the sleigh, I was pressed for time to give it to her on Christmas Eve so she could use it. The runners are copper on the sleigh and the sleigh is 16 gauge stainless.
Figure this is a good way to collect more exotic part stuff for TIGGY by making her happy with it. time to expand the TIG collection
Reindeer ready for assembly
These where a pain in butt to do
Production line building bodies and legs the prototype looks on
Welded bodies
Attaching necks to head
fancy neck jig lol
heads waiting to be attached
head jig
- reindeer1.jpg (62.91 KiB) Viewed 1764 times
- reindeer2.jpg (61.48 KiB) Viewed 1764 times
- reindeer3.jpg (48.16 KiB) Viewed 1764 times
- reindeer4.jpg (49.33 KiB) Viewed 1764 times
- reindeer5.jpg (54.46 KiB) Viewed 1764 times
- reindeer6.jpg (48.77 KiB) Viewed 1764 times
- reindeer7.jpg (39.35 KiB) Viewed 1764 times
- reindeer8.jpg (42.58 KiB) Viewed 1764 times
- reindeer9.jpg (44.76 KiB) Viewed 1764 times
- reindeer10.jpg (44.13 KiB) Viewed 1764 times
- reindeer11.jpg (51.84 KiB) Viewed 1764 times
- reindeer12.jpg (37.45 KiB) Viewed 1764 times
- reindeer13.jpg (49.3 KiB) Viewed 1764 times
And the stockings were filled.
Everlast 250EX
- big gear head
Hollywood1
- Hollywood1
Bent my first hoop today! Came out great. I need some advice please on some 1 5/8" .134 mild steel tubing. Welded both at 130 starting amps the first with 1/16th filler and the second with 3/32 filler. Do you need to shove the rod into the metal pretty hard, as I have just been dippin. As always, I appreciate the advice. Thanks John.
- 20160101_151306.jpg (39.46 KiB) Viewed 1694 times
- 20160101_151234.jpg (35.63 KiB) Viewed 1694 times
- 20160101_133516.jpg (24.27 KiB) Viewed 1694 times
Hollywood1
- Hollywood1
- MosquitoMoto
Sorry Hollywood, a question rather than an answer...are you starting out on 130 amps and then backing off to lower 'main welding amps' as you go? 130 seems high to me, but as a noob that's just a gut feel thing.Hollywood1 wrote:Sorry the 3/32 is the top weld.
Can't argue with the results - your bends and welds are looking great!
Kym
If you use the 1/16" then dip quicker, your (1/16" weld) bead isn't "full" enough. The 3/32" looks good (not cold) and full to me.Hollywood1 wrote:Bent my first hoop today! Came out great. I need some advice please on some 1 5/8" .134 mild steel tubing. Welded both at 130 starting amps the first with 1/16th filler and the second with 3/32 filler. Do you need to shove the rod into the metal pretty hard, as I have just been dippin. As always, I appreciate the advice. Thanks John.
Hollywood1
- Hollywood1
Hollywood1
- Hollywood1
So I have been trying to build my skills by running beads on practice coupons, but today I had need to actually use my machine to make something useful.
This is a bracket that will be used to mount a light to a metal framed bed in a doctors surgery. I was fairly happy with the first side weld but the second side is not all that good. The saving grace is that there is not a whole lot of loading that will be applied and the welds will be sufficiently strong and the back side weld is hidden from view.
The plate is 1/8" mild steel and the curved part was sectioned from galvanised pipe. I learned an important lesson that ALL the galvanising needs to removed prior to welding! I had partially removed the galvanising but it still contaminated the second weld and produced a lovely white powder underneath the part.
As for settings I had the machine set to 150amps but was using a foot pedal, about 8 lpm gas flow, 1.5% 3/32" Lanthanted tungsten, 3/32" ER70S-6 filler.
Flo
- 20160102_125419_resized.jpg (80.86 KiB) Viewed 1773 times
- 20160102_125403_resized.jpg (68.37 KiB) Viewed 1773 times
- 20160102_125409_resized.jpg (64.07 KiB) Viewed 1773 times
- big gear head
The first weld probably caused oxidation on the other side, which made your second weld not as good as the first.
Freddie
That makes sense. So I either need to shield the back side with argon whilst welding the first side or remove the oxides mechanically prior to welding the second side..big gear head wrote:The first weld probably caused oxidation on the other side, which made your second weld not as good as the first.
Cheers,
Flo
AFR_Autoworks
- AFR_Autoworks
This is my first cage welded with my new Dynasty. I used to use a torch mounted switch and no amperage control. I must say I have fallen in love with th Miller pedals. They stay put and don't slide around so out of position welds are achievable.
- image.jpeg (59.95 KiB) Viewed 1702 times
- image.jpeg (65.73 KiB) Viewed 1702 times
- image.jpeg (33.88 KiB) Viewed 1702 times
- image.jpeg (59.97 KiB) Viewed 1702 times
Hollywood1
- Hollywood1
- big gear head
Nice work. I don't think I've ever seen a cage built like that before. What will this car be used for? Looks like it might be Ralley or drift judging by the long lever in the center.
Freddie
Not a bunch. Added some 3/4 pipe braces, made a 1 1/2 x 1/8 angle frame and tossed some 3/4/9 expanded on it for a drop shelf. Coat of roof paint.Wire wheeled and Ospho'd the top. 3 coats of floor wax.Good to go until next year.
I think I'll make some extensions to slide into that 1x2 tube for longer material.
Its 40 tall, 40 wide and 60 long. 1/8 wall tube and 1/4 lid. Flat as glass.
- mesadesoldar.jpg (61.71 KiB) Viewed 1824 times
AFR_Autoworks
- AFR_Autoworks
The car will be used mainly for drifting however the cage is build to be FIA compliant. It will be legal for any type of racing he wants to do. The windshield braces are a required member in any FIA cage as of 2005. In the event of a rollover the windshield is the weakest area
AFR_Autoworks
- AFR_Autoworks
Haha you get used to it! The key is to get in feet first and sit on the door bar. Road race/ drift/ rally cars don't have the luxury of swing outs like drag cars. Drag cage regulations are very lax.
