I am a hobby welder and want learn to weld aluminum. I would like to post pictures of my welding progress to see if it helps motivate me to improve.
Here is yesterday's effort.
Your getting there Gene, like Richard mentioned just make sure to lower amperage at the end of the bead and add extra filler, craters and the end are known for cracking.
Pete
Not too shabby! How thick is the plate?
Since I was playing I decided to try some lap joints and eventually ended up getting to joints similar to the ladder I want to build. Here is the good one.
- ThdeGood.JPG (17.21 KiB) Viewed 2654 times
Did you use a chemical to clean the aluminum before you welded it? That blue is not something I've seen, but it certainly looks as though the start of that weld is rather wonky. No gas, or tungsten touching the alloy, or both...
Strange blue. Your practice looks good to me, even and structural. Those craters are an easy fix if you want. You using pedal, 4T or 2 T?
Nelson
Nelson
There I was minding my own business when this wasp attacked me. Well, not exactly me but the arc! All I knew was that the arc went funky just as I started. When I looked, there was a wasp laying right there.
- Wasp.JPG (28.5 KiB) Viewed 2308 times
