- IMG_2210.JPG (36.26 KiB) Viewed 3164 times
- IMG_2213.JPG (81.54 KiB) Viewed 3164 times
- IMG_2214.JPG (34.01 KiB) Viewed 3164 times
- IMG_2211.JPG (39.82 KiB) Viewed 3164 times
Fortunately I was able to do most of the work ahead of time. the only thing left on shutdown day what's to bolt up the last 4 inch flange and do the two welds on the tee.
Made a nice adjustable engine support while I swap the junk auto out of my TDI Jetta. A few pics of some oher stuff I'm building...
- IMG_20170601_013320411.jpg (54.83 KiB) Viewed 3056 times
- IMG_20170525_152239941.jpg (53.47 KiB) Viewed 3056 times
- IMG_20170601_175320199.jpg (59.28 KiB) Viewed 3056 times
- IMG_20170601_225317936.jpg (61.08 KiB) Viewed 3056 times
- Tooling storage cabinet I'm building
- IMG_20170606_153305186.jpg (59.58 KiB) Viewed 3056 times
- IMG_20170609_193221405.jpg (58.67 KiB) Viewed 3056 times
- Oil pan repair
- IMG_20170611_162050726.jpg (50.77 KiB) Viewed 3056 times
- IMG_20170612_084606106.jpg (63.48 KiB) Viewed 3056 times
- IMG_20170612_084556432.jpg (49.61 KiB) Viewed 3056 times
- 5th Street Fab
Lucky man! I got to finally use some at work today. I'm hooked. Now if only they would get it for everyday use!Otto Nobedder wrote:Sweet!5th Street Fab wrote:... I finally got a bottle of helium at home...
I have the incredibly rare blessing of completely unlimited access to helium. One of our clients provides whatever we ask for because I use it in leak detection.
Steve
Today i made two simple cordless drill holders and weld four adjustable legs for an assembly table made for line assembly of kitchen ovens. All make with 304 stainless steel scarp from ovens productions, the square tube for the legs are just 1mm thickness tig welded
- IMG-20170609-WA0028.jpg (85.8 KiB) Viewed 3509 times
- IMG-20170609-WA0010.jpeg (43.28 KiB) Viewed 3509 times
- IMG-20170609-WA0006.jpeg (36.15 KiB) Viewed 3509 times
- IMG-20170609-WA0003.jpeg (57.84 KiB) Viewed 3509 times
- 5th Street Fab
This was terrifying but so exciting! I posted earlier the beginnings of this, now it's all done, just need to add some sensors and pressure references, maybe a brace to the block. Last week I finally got off my ass and bought the plenum metal, and went to my friend's shop with a big press with my angle and rod to bend it. It worked well with the experiment with the coolant tank so I was cautiously optimistic. But even with 3003, it is just too much length with a single pressure point. The 1.5" solid aluminum bar bent before making much of an impression on the sheet (3/16" thick). I called several audibles, one was a steel jack handle, that crushed. Finally we found a 1.5" solid STEEL bar, I cut it to length and that finally worked. It almost seemed like it wasn't going to, it was bending a lot but wasn't yielding and when it bottomed out in the angle, it straightened out the bend. PSI is a bitch, I'm from an RC airplane model background and I should have an appreciation for load distribution but it's still hard to picture intuitively.
Alls' well that ends well, I'm SUPER stoked with the end result, I was cautiously optimistic that my skill level was now where it needs to be but I always tend to attempt things when they're at least a notch outside of my comfort zone and sometimes ability but that's what makes it fun...
- intake manifold 1.JPG (67.72 KiB) Viewed 3424 times
- intake manifold 2.JPG (91.87 KiB) Viewed 3424 times
- intake manifold 3.JPG (66.36 KiB) Viewed 3424 times
- intake manifold 4.JPG (95.62 KiB) Viewed 3424 times
Farmwelding
- Farmwelding
That looks fancy and like you did a heck a job welding that all out.
Instagram: @farmwelding
Nick
Nick
My filler tooling cabinet is complete finally and out on the floor.
- IMG_20170620_180013848.jpg (70.8 KiB) Viewed 3248 times
jernigan78
- jernigan78
Finished a new welding positioner project that I have been working with a local machine shop on. Ran some tests, works well. Played around last night running some autogenous welds with the torch strapped to my steady-rest. These were done at 2pps. Different amp settings for the different spots. I guess its a pen holder for my desk at work. haha.
- IMG_8752.JPG (55.18 KiB) Viewed 3772 times
- IMG_8744.JPG (78.7 KiB) Viewed 3772 times
- IMG_8742.JPG (58.33 KiB) Viewed 3772 times
- IMG_8741.JPG (57.15 KiB) Viewed 3772 times
- IMG_8740.JPG (89.06 KiB) Viewed 3772 times
Looks great, would like to know more about your rotator buildjernigan78 wrote:Finished a new welding positioner project that I have been working with a local machine shop on. Ran some tests, works well. Played around last night running some autogenous welds with the torch strapped to my steady-rest. These were done at 2pps. Different amp settings for the different spots. I guess its a pen holder for my desk at work. haha.
Awesome looking beads..
Pete
- GreinTime
The whole thing was done consecutively alternating joint to joint. I think it's 4" sections maybe?Oscar wrote:The titanium came out nice! Sucks having to wait for it to cool down though.
