Last Night I had turned my Boombox and Dynasty on to warm up, didn't want to turn on my Coolmate cause I didn't want to have to listen to it run while I prepped the aluminum part to weld. Put my gloves and hood on and proceeded to weld about a 8" bead on aprx. 3/16" thick part, I did notice that my tungsten looked overheated after the weld and the torch a CK 230 Flex felt warmer than usual, then I noticed that it was to quiet in my shop, forgot to turn on my darn cooler!! Should I be checking anything out on it?? I turned the cooler on after words and did a couple of test beads and everything seems to still work fine??
Thanks in advance
Pete
Thanks guys! The older I get the more forgetful I get! lol
Pete
my newest dumb this is to let the cable from the foot peddle under the edge
of the pedal so when i try to tack i get half pedal, thus no tack.
this has happened a few times doing aluminum also. everyone knows
how that turns out....
Farmwelding
- Farmwelding
Based on the first sentences I thought it was gonna be that your tig welder messed with your speaker. I was running some aluminum off of a diversion 180 the other day and my teacher yells at me and says look what you did. About half way through the CNC program he was running it just shut off and seized up due to me welding. I guess AC tig will do stuff like that. Or when I am in the booth next to someone welding on aluminum my helemet won't shut off in X-mode since that crap goes through every nook and cranny
Instagram: @farmwelding
Nick
Nick
Here's what happens to a water-cooled return/power lead when you accidentally pinch the flow at 310 Amps...
- GEDC1030.JPG (206.45 KiB) Viewed 2487 times
Seconds. It did not smell good, either.LtBadd wrote:Bet that didn't take long...Otto Nobedder wrote:Here's what happens to a water-cooled return/power lead when you accidentally pinch the flow at 310 Amps...GEDC1030.JPGSteve S
Looks like that got hot in a hurry Otto! Luckily my machine was set for about half of that!
Pete
Pete
Pete
3 sec at 200A AC without water was enuogh to melt the water hose. Power hose made it so it was just to cut off an inch and it was fit for fight again
Farmwelding
- Farmwelding
All I know is that I wouldn't want to to anything to ruin a water cooled torch. I learned on a 17 and then went to a water cooled for a few months at a local tech school (not a ton of hours but enough). I came back now and burn my hand everyday running from 120-180 amps almost non-stop. I have to stop after a half an hour so I don't burn my hands all the time.
Nick
Nick
Yah, I hear ya! When I bought my first Tig welder I bought a air cooled torch to save on $ and they do get hot!!Farmwelding wrote:All I know is that I wouldn't want to to anything to ruin a water cooled torch. I learned on a 17 and then went to a water cooled for a few months at a local tech school (not a ton of hours but enough). I came back now and burn my hand everyday running from 120-180 amps almost non-stop. I have to stop after a half an hour so I don't burn my hands all the time.
Pete
Craig, 1 word buddy WIRELESS...lol I love my wireless pedal as I find myself trapping the damn cord at times on the wired pedal we have on the main shop welders as I move it around the table. Getting it under a stool leg is popular for me too...lolmotox wrote:my newest dumb this is to let the cable from the foot peddle under the edge
Farmwelding
- Farmwelding
Unless your machine has no way to change foot pedals with that style connection and only accepts Ethernet cable ends and doesn't allow you to easily replace torches or stick weld (Miller diversion 180 he says while coughing)Rick_H wrote:Craig, 1 word buddy WIRELESS...lol I love my wireless pedal as I find myself trapping the damn cord at times on the wired pedal we have on the main shop welders as I move it around the table. Getting it under a stool leg is popular for me too...lolmotox wrote:my newest dumb this is to let the cable from the foot peddle under the edge
Nick
Nick
Pete, I should have mentioned it was AC welding, so tons of heat in the torch, lead, and coolant already. The steam looked like smoke (and there was smoke from the burned hose), and someone ran up and killed the disconnect at my power outlet PDQ. I was doing a long 1/2" aluminum 4G from a creeper, and rolled a wheel over the supply line, and "poof", all gone.pgk wrote:Looks like that got hot in a hurry Otto! Luckily my machine was set for about half of that!
Pete
I was doing 1/4 or 3/16" 3003 diamond plate once, blasting my welder for hooooooours. Had to keep on stopping because the torch got too hot. Ended up grabbing a bucket of cold water and I would dip the torch it in, worked just about once
Must be kind of hard on those alumina cups, I'd think...Olivero wrote:I was doing 1/4 or 3/16" 3003 diamond plate once, blasting my welder for hooooooours. Had to keep on stopping because the torch got too hot. Ended up grabbing a bucket of cold water and I would dip the torch it in, worked just about once
Steve,Otto Nobedder wrote:Pete, I should have mentioned it was AC welding, so tons of heat in the torch, lead, and coolant already. The steam looked like smoke (and there was smoke from the burned hose), and someone ran up and killed the disconnect at my power outlet PDQ. I was doing a long 1/2" aluminum 4G from a creeper, and rolled a wheel over the supply line, and "poof", all gone.pgk wrote:Looks like that got hot in a hurry Otto! Luckily my machine was set for about half of that!
Pete
That had to be quite the surprise!
Pete
