Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Random stuff from last week, been swamped with repairs and haven't posted much.
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
rick
always interesting to see what you welded.
have you ever welded the same type of repair
twice...lol
Rick_H
    PA/MD
motox wrote:rick
twice...lol
Thanks Craig, yeah I do some repetitive repairs but what I like about my job is most days bring a new surprise.
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Rupes wrote:Started practice on welding SS today. Cut about 30 strips to weld back together.
Between 0.55mm and 0.7mm
First ones looked pretty crap. But fiddled with the settings and got something good enough for the moment.
I'm planning on fabricating a 0.55mm inconel exhaust for my bike early next year. Far cheaper to practice on SS though.
As it turns out inconel welds better than SS ... well for me anyway.
https://goo.gl/photos/PNZvFcDA9E6Ftkao9
Nice work.
The exhaust is for your TL, yes? (I seem to remember you'd also fabricated a custom frame for this one?)
Can I ask where you'll be sourcing your tubing? Where I am, the thin wall stuff is hard to find.
Kym
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
Y pipe for a BMW E30 with a 5 series V8 swap.
I have to do some control arms for a friend for his Dodge that I'll post some pics later this week
Rick_H
    PA/MD
Looks good Sam
    Pittsburgh, PA
His dad being a machinist is a beautiful thing when he finds scrap 2.5" brass round stock in the scrap bin. R/L threads, as well as a set for the bigger rod end bushings I have to weld on the long arms.
    Thu Dec 25, 2014 9:25 am
    near Chicago
Did a little dentistry on a chipped lathe gear tooth this afternoon. A little pre-heat and then some silicon bronze filler. Let it cool down and then got after it with a file. Couldn't get a real good pic because of the flash washing everything out. Going to finish it up in the morning and add another pic.
Tom Osselton
    Sat Aug 15, 2015 12:33 am
    Calgary Alberta
Looks good! I've heard of drilling and tapping the tooth for a set screw to increase the strenth of the tooth.
It looks like we have the same gear damage.
    near Chicago
I heard of that too but this was just a corner that got knocked off like someone dropped a chuck or something on it so I just cleaned it good and bronzed it. I want to get that sharp corner back but I had a few beers while I was filing and thought I might wait til tomorrow to finish it so I don't make it worse :lol:
motox
    Delaware
removing a broken set screw by tig welding a tit on it
to grab with vice grips when its to small to weld
a nut to it.
motox wrote:removing a broken set screw by tig welding a tit on it
a nut to it.
Good job, always a good feeling when they back out, especially broken taps. When possible I weld a cap head bolt and use an allen wrench
motox
    Delaware
yes but this was a #10 set screw to small to add to.
    near Chicago
I see an old Logan lathe back there in your shop. Tell me more!
motox
    Delaware
jeff
finally got it back together. had to disassemble it to
get it from my house in NJ to its new home in Delaware.
its old but it works very nice. i have a small setup for
the tool post to mill small items.
hope your lathe is up and running.
    near Chicago
motox wrote:jeff
Mine is up and running. I ordered a QCTP and some tool holders and spent the whole day yesterday tweaking it. Everything works good except for my damned 3 jaw chuck has a lot of runout. I know the nature of the beast that they aren't really accurate but it still bothers me. I am going to try switching the jaws into different holes and some other tricks to try to get it a little tighter but overall the lathe is good enough for what I intend to use it for. Now I wish I has mill....damn..I knew it :(
motox
    Delaware
"Now I wish I has mill....damn..I knew it :("
nice to have but anything good is three phase
and big.....
Tom Osselton
    Calgary Alberta
The jaws are numbered to each slot otherwise the chuck will not close properly!
Have you checked the theads / cam lock for chips that would affect it?
    near Chicago
Tom Osselton wrote:The jaws are numbered to each slot otherwise the chuck will not close properly!
I dis-assembled the chuck and cleaned it out and oiled it.It was stuffed full of chips. Being a noob I didn't scribe my chuck as to where the jaws are supposed to go so I probably put the jaws in the wrong place. I switched things up today and she is running really good. .0004 runout on a 3 jaw that is 70 years old...I can live with that.
    near Chicago
motox wrote:"Now I wish I has mill....damn..I knew it :("
and big.....
NO 3 phase in my shop...dammit...I guess I'll have to piss away the :lol: 4 or 5 G's on alcohol then
dunkster
    Sun Jun 28, 2015 7:41 pm
    Florida
exnailpounder wrote: NO 3 phase in my shop...dammit...
that's what VFD's are for!
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
and cobbled up Rotary Phase converter, RPC build your own. Info all over the net,simple to elaborate.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
motox
    Delaware
all the phase convertors i have been around are very loud
when operating and its one more motor you have to find a home
for.
Not all old three phase motors are freq drive compatible.
    Sat Dec 03, 2016 9:22 am
Well,
I’m still new to this forum, but wanted to make a contribution to the Recent Welding thread here as soon as possible, as I think that’s where the most significant stuff occurs on forums like this. I don’t do lots of welding like I once did, and I have a minimum of tools and equipment to use now, which I like, but I still have a lot of enthusiasm for new fabrication and modification of existing stuff.
Motor Swap.jpg (70.99 KiB) Viewed 2020 times
Normal Exhaust.jpg (60.85 KiB) Viewed 2020 times
Anyway, here’s a fun one that I’m doing by re-powering a zero-turn mower, from a 12hp Single to a 20hp Twin, since I put a bigger deck on it at the beginning of the mowing season and added a higher compression cylinder head to make it work OK with the 12hp motor. And it did, but now it burns oil and seems to be loosing a bit of torque too. So, it’s going bye-bye.
Cut Tube.jpg (54.97 KiB) Viewed 2020 times
Cut Out.jpg (57.86 KiB) Viewed 2020 times
Surprisingly, I got the 20hp Twin for the price of a 18hp Single. But I didn’t like how the two-into-one exhaust protrudes out the back end and how it gets in the way of the throttling mechanism.
Make a Hole.jpg (53.81 KiB) Viewed 2020 times
Fit Up.jpg (42.03 KiB) Viewed 2020 times
So, I decided to duck it down under the motor mount. And it’s going well, even though I didn’t recognize that the exhaust had an aluminized coating, as I only ground off what I though was some high temp silver paint.
Tack Up.jpg (53.62 KiB) Viewed 2020 times
Weld Up.jpg (44.05 KiB) Viewed 2017 times
But, no matter. The fit up was good. The new geometry was all good. The welding was nothing to be proud of or ashamed of. Besides, paint covers a multitude of welding sin.
I’ll probably delete that heat shroud so that the trailer hitch can shoehorn back where it was. And I’ll undoubtedly be doing more to it this winter, like fabrication an aluminum diamond plate gas tank and moving it up front under the footing area, while using an electric fuel pump. The existing gas tank had a bulletin or recall one it years ago, not that I'm worried about it. I just dig a brushed metal finish on aluminum diamond plate, and maybe the weight center being lowered and brought forward would be a good thing too.
Peace be with you all,
Christian Livingstone
Everlast AC/DC 210EXT (2015)
CAT250D DC-TIG/Plasma Combo
