Little sifter screen repair for a product feeder. I ended up cutting the old piece out and welding in a new section. Not the coolest thing I do but I do a lot of these based on vibration damage....the wire mesh is .090". They have to be welded sanitary with no crevices.
- IMG_20160730_205053.jpg (72.13 KiB) Viewed 1997 times
- IMG_20160730_212117.jpg (52.13 KiB) Viewed 1997 times
- IMG_20160730_223034.jpg (79.38 KiB) Viewed 1997 times
[/attachment]
A cracked Olds intake manifold that I repaired.
- final weld OLds.jpg (37.4 KiB) Viewed 1956 times
- cracked olds.jpg (49.1 KiB) Viewed 1956 times
- grooved out.jpg (71.16 KiB) Viewed 1956 times
- IMAG0176.jpg (55.17 KiB) Viewed 1956 times
Made a cart to hold all the parts to a labeler at work to prevent damage. I made one a year ago and damage is own 98% just have to cap somethings off and do the finish work.
- IMG_20160731_214847.jpg (65.09 KiB) Viewed 1925 times
- IMG_20160731_214523.jpg (69.37 KiB) Viewed 1925 times
- IMG_20160731_214505.jpg (71.51 KiB) Viewed 1925 times
- subwayrocket
Made a Speed Handle for my mill vise . All scrap from the junk yard .
- 1ViseWheel.jpg (43.32 KiB) Viewed 1911 times
- 2ViseWheel.jpg (52.27 KiB) Viewed 1911 times
- 3ViseWheel.jpg (80.58 KiB) Viewed 1911 times
- 4ViseWheel.jpg (66.51 KiB) Viewed 1911 times
That should work nice! A lot easier to grab that is for sure ...
Is the Mill up and running?
- subwayrocket
Thanks, yes it's all set up. Cosmoline all cleaned off, oiled, re-greased, trammed. Getting to know the machine. Matt at Quality Machine Tool in Pittsburgh has been a big help. I started doing a few things with it. I milled flats on the shank of all my import Shars boring bars. Faced all my big Alum chill blocks . Hoping to get a machinist buddy down here to get me going better ! The speed wheel works pretty good. It's weight gives it some inertia like a fly wheel...so opening/closing goes faster. Threw some paint on it...and since it's the only American made thing on the whole mill I threw the little flag on it ...lol . Here it is on the mill .Rick_H wrote:That should work nice! A lot easier to grab that is for sure ...
- SpeedHandle-onMill-Painted.jpg (69.33 KiB) Viewed 2211 times
- Buddy.jpg (84.23 KiB) Viewed 2211 times
- maker of things
Finally good use for Harbor Freight indicator base
- IMG_20160723_110923565.jpg (92.18 KiB) Viewed 2196 times
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
- maker of things
Ace, nice setup. Once you have used a speed handle on a mill vise, it's pretty had to imaging not having one huh? I share your opinion of Matt. Got my 1440 lathe from him and am very happy with his machine and service.
-Jon
- subwayrocket
Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$maker of things wrote:Ace, nice setup. Once you have used a speed handle on a mill vise, it's pretty had to imaging not having one huh? I share your opinion of Matt. Got my 1440 lathe from him and am very happy with his machine and service.
- maker of things
ain't that the truth! My rule on that:subwayrocket wrote:Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$
Give a person a tool, they can finish a project. Give that same person a reasonably equipped shop and they will forever be one tool/machine away from starting yet another project.
-Jon
I always wished my tool was bigger...sorry...you asked for itmaker of things wrote:ain't that the truth! My rule on that:subwayrocket wrote:Yep . The only problem I have found with a mil is that once you have one, you want a bigger one ...and a lathe too $$$
- maker of things
Some hanger-uppers for torches and work cables on the end of my weld bench.
- weld shop 010.JPG (48.1 KiB) Viewed 2083 times
-Jon
Making some stuff...
Steel tank legs, stainless frame I made 309L wire
- IMG_20160809_235650796_BURST000_COVER_TOP.jpg (37.62 KiB) Viewed 1932 times
- IMG_20160809_231347993.jpg (72.5 KiB) Viewed 1932 times
- entity-unknown
Is that "Passover" tank for that special holiday feeding time?
Lincoln Electric AC225
Everlast W300 WaterCooler
Optrel e684x1
Optrel e684x1
Was an old vessel we used for some special Passover items we make at work.entity-unknown wrote:Is that "Passover" tank for that special holiday feeding time?
- maker of things
- IMG_20160810_151256471_HDR.jpg (56 KiB) Viewed 2223 times
-Jon
I bought a wrecked car a few months ago with the intentions to turn it into a race car. Well, my daily driver caught on fire so I had to whip the project into shape in short order.
What I started with.
In progress.
Done other than tweaking the headlight bucket on the driver's side a little bit.
In progress.
Melt all the things.
- maker of things
- IMG_20160813_090953806_HDR.jpg (107.85 KiB) Viewed 2107 times
-Jon
Got my fittings welded in, tank and stand complete now to add some process piping and a filter.
- 2 passes, 309L steel to stainless on the legs.
- IMG_20160809_235650796_BURST000_COVER_TOP.jpg (37.62 KiB) Viewed 2068 times
- IMG_20160812_204423870.jpg (51.36 KiB) Viewed 2068 times
- IMG_20160812_204411284.jpg (31.41 KiB) Viewed 2068 times
- Inside welded, grind smooth and polish...happy since I was leaning down inside the tank upside down.
- IMG_20160812_194419726.jpg (65.71 KiB) Viewed 2068 times
Cementite nice project!
Thanks Rich...
Stand mocked up in place, need to wait till the tank and cleaned then Ill paint the stand with some Steel-It and they will sanitize and put into production.
- My setup today....
- IMG_20160814_184354186.jpg (89.25 KiB) Viewed 2013 times
- Polished out, weld nearly disappears
- IMG_20160814_195522.jpg (30.48 KiB) Viewed 2013 times
- 316L, sanitary, back purge
- IMG_20160814_194439629.jpg (39.72 KiB) Viewed 2013 times
- IMG_20160814_215616847.jpg (87.71 KiB) Viewed 2013 times
