Yeah I use V blocks as well, just find what ever works depending on if I'm on a bench or in the plant somewhere, I never take for granted someone previous made their work square, got me a few times.... These clamps are the same way, they show the slightest in perfection. My Exact pipe saw does a pretty decent job, then I file if needed, the cut and fit is the hardwork, the weld is easy.LtBadd wrote:I always used precision vee blocks to lineup elbows and tees to tube. With the elbow facing up of course, it does a good job mating them for tacking. If the fitup is the least bit off it shows like a sore thumb.Rick_H wrote: With no tangent at all these will not work, I cheat them over to get them to clamp on these that have around 1/2" true tangent. I finally got a set of these after taping for years, they really are nice when your mocking up stuff or are in the ceiling. These are TIG tack clamps by Tech South. http://www.techsouthinc.com/pipeclamps/sanitary.html![]()
I've purchased from TechSouth before, knowledgeable guys there.
AFR_Autoworks
- AFR_Autoworks
Hey guys, I have been so busy with the shop lately I have totally forgot about this place. Here are a few pictures of some recent projects.
- Downpipe welds
- image.jpeg (48.31 KiB) Viewed 1974 times
- Downpipe fit up
- image.jpeg (45.57 KiB) Viewed 1974 times
- Turbo manifold
- image.jpeg (46.7 KiB) Viewed 1974 times
- Titanium Intake
- image.jpeg (70.22 KiB) Viewed 1974 times
kiwi2wheels
- kiwi2wheels
- subwayrocket
Welded up a skid plate, it had been hard anodized, what a PITA.
So for the hell of it I had some 1" square anodized AL blocks.
Welded them together at 225 and 325 amps.
Wanted to see what the weld nugget looked like. So thought I would share.
6061 Blocks using 4043 filler rod.
Was not trying to make it pretty, and given the amount of crap that was floating up couldn't if I wanted to.
![Image](https://photos.smugmug.com/Other/Welding/i-WrpqDV2/0/L/CA_07191616144192-L.jpg)
AFR_Autoworks
- AFR_Autoworks
Thanks for the kind words guys! I am still learning and progressing a ton with each job. Sorry to post again so soon but I was doing some more exhaust work today and these are my best welds to date IMO.
- image.jpeg (70.53 KiB) Viewed 1851 times
- image.jpeg (31.82 KiB) Viewed 1851 times
- image.jpeg (41.85 KiB) Viewed 1851 times
- MosquitoMoto
AFR
did you use the same stick out as shown to
achieve those pretty welds?
if so what kind of gas flow?
very nice!
very nice!
AFR_Autoworks
- AFR_Autoworks
Hey Craig, yes I did use that amount of stickout. I almost always run 25 CFH unless I have to do some insane weld where I need more stickout. With this cup I have been able to run over 2" and still see coverage.
AFR
i dont do a lot of stainless but for
tight places in steel tubing that would
be a tremendous help.
thanks for setup info.
Finished up a bunch of little projects last night at work, have a full workload today have to finish welding up a filler.
- IMG_20160722_172342.jpg (59.21 KiB) Viewed 1952 times
- Rocking with my Superior Welding Unbreakable Cup
- IMG_20160722_192958562_HDR.jpg (47.41 KiB) Viewed 1952 times
They are capped solid no hole, they are just some fancy stands for some Video Jet Printer cleaning stationsLtBadd wrote:Hey Rick, looks like these are capped on one end and a bracket on the other, is there a weep hole anywhere, and what are these used for...?Rick_H wrote:Finished up a bunch of little projects last night at work, have a full workload today have to finish welding up a filler.
- subwayrocket
Thaks, the lower LH corner I assume is what you are talking about... they are actually reflector mounts for some photo eyes..subwayrocket wrote:Nice stuff Rick ! Are those your back shielding boxes next to the finished brackets ?
Just a machine guard...
- IMG_20160726_234924.jpg (42.9 KiB) Viewed 1791 times
- IMG_20160726_233208.jpg (55.95 KiB) Viewed 1791 times
What is chucked up on that tool?Rick_H wrote:Just a machine guard...
It looks like a flapper wheel of scotch-brite pads, though I'm assuming it has some specific name and painful price.
-Josh
Greasy fingered tinkerer.
That is a Metabo burnishing machine PT# 12-115, with a scotchbrite style flapper, 900grit at that point. I work in a food plant so finishing is very important, this is one tool I am not sure how I lived without, expensive but worth every penny IMO. You can put the grain back in stainless and blend it so you can not even tell. It has a neat little attachment where I can use scotchbrite or sand belts to polish all around piping.hey_allen wrote:What is chucked up on that tool?Rick_H wrote:Just a machine guard...
Here's a cool video https://www.youtube.com/watch?v=eKgGoVjC4js
https://www.metabo.com/us/enus/tools/cu ... chine.html
fredygump
- fredygump
sticking with the 4B stainless theme... I think this is a wall mounted garbage can, maybe for biohazard waste? It's for a hospital.
We use the Walter 2 in 1 wheels to polish and fix/replace grain. Same idea as in the post above.
- IMG_20160729_082801.jpg (48.49 KiB) Viewed 1663 times
- GreinTime
Ughhh that dreaded film lol. We do a lot of different finished stuff at work and if I never had to work with a film covered piece of stainless again I'd be a happy man. Mirror finish, bead blasted plain, bead blasted with epoxy ink that gets dissolved off with solvent, leaving bright shiny stainless in whatever pattern they had printed (looks cool as fuck), brushed, you name it, it's in a trash receptacle, park bench, or picnic table somewhere lol
I know how you feel, sometimes I think you can scratch stainless if you look at it the wrong wayGreinTime wrote:Ughhh that dreaded film lol. We do a lot of different finished stuff at work and if I never had to work with a film covered piece of stainless again I'd be a happy man. Mirror finish, bead blasted plain, bead blasted with epoxy ink that gets dissolved off with solvent, leaving bright shiny stainless in whatever pattern they had printed (looks cool as fuck), brushed, you name it, it's in a trash receptacle, park bench, or picnic table somewhere lol
![Confused :?](./images/smilies/icon_e_confused.gif)
Warps too if you look at it wrong...lol I've got some special lens for your welding helmet that takes care of that issue, they are only $99.99 plus $8 shLtBadd wrote:I know how you feel, sometimes I think you can scratch stainless if you look at it the wrong wayGreinTime wrote:Ughhh that dreaded film lol. We do a lot of different finished stuff at work and if I never had to work with a film covered piece of stainless again I'd be a happy man. Mirror finish, bead blasted plain, bead blasted with epoxy ink that gets dissolved off with solvent, leaving bright shiny stainless in whatever pattern they had printed (looks cool as fuck), brushed, you name it, it's in a trash receptacle, park bench, or picnic table somewhere lol
- subwayrocket
Just a little hand tool I made so I don't have to fumble around with a wrench on the draw bar above the mill .
Got a bunch of these 304 knurled knobs off food service machines at the scrap yard, knew they'd come in handy.
Don't know exactly what the socket is made of so used some 625 rod.
- DrawBarTool.jpg (43.43 KiB) Viewed 1883 times
