infernoST
    Thu Jun 02, 2016 10:12 am
Hi all
Does anyone know the amperage rating on the 9 size torch that comes with the Everlast Powertig 210 EXT?
Keith
    Thu Jan 24, 2013 12:13 pm
9 torches are pretty much all rate around 125 amps from what I've seen irrespective of brand - they will mostly take a bit more if you don't keep on it for too long - generally the torch is fine but the power connection in the handle will melt first ( ask me how I know ! ) so when you hand is smoking stop & hang the torch in front of a fan of extractor if you got one.
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
...and even less if you do AC welding with ~65-70% EN balance. They'll start smoking in about 60sec with any respectable amount of amperage.
infernoST
Thanks for the feedback guys, I'll keep the ac limitation in mind when I get to aluminum for now I'm just working on cold rolled steel 1/8 & 3/16'th. Still running beads
Keith
